0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Hello everyone, I know it’s been quite a while since I’ve posted anything on the website, I have since moved from Michigan to Colorado which poses its unique changes to an engine when you go from 600 to 6000 feet above sea level. Anyway I have a 54 deluxe Chevy pick up with Hydromatic. What seems to be happening ever since I came here was once I put the vehicle in to drive there seems to be this clickety clack noise coming from the front of the engine one placed in drive like around the timing chain, maybe it’s the circumstances that the timing chain needs to be replaced, I don’t know, anyone have any interesting responses? thank you TODD | | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | what is your engine? a original six does not have a timing chain, just gears
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Fan blades hitting something? I once had a noise like that with the fan touching a block heater plug.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Remove the fan belt for a short time and see if the noise is still there. That will help you determine if the noise is internal or external. A cold engine should be able to run for at least a couple of minutes without overheating, even if the fan and water pump aren't turning. Jerry
