1 members (Naturalthud), 110 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
#1411389 05/26/2021 10:19 AM
Same old question... Swaping out my front end on my 1950 3/4 ton Chevy. Do you know of any build threads or advice on stunning an s10 front stub or 1974 nova? Any advantages to either? Thanks for any help.
First thing is to check the widths and see what works. For some reason I favor the Nova?!!
Not a fan of the S-10 Swap. Others will disagree. Nova, Camero, Firebird are by far the more truck compatible options. Measure 15-20 times before you cut your frame. Make sure everything is square before tacking in place. Measure 15-20 times again and do the final welds. Lots of YouTube videos on the procedure. Educate yourself and rock on!
Or, find what you need right here at the Stovebolt!! Stovebolt Tech Tip
Camaro clips can be a bit wide for the 3100 series. You might need to do some measuring for your 3/4 ton. Or, plan on what you'll need to do to make you happy. My plan from the start, for my 3106, was to install narrow A-arms. It worked out well for me and I'm happy.
Having participated in many front subframe changes on round track race cars due to wreck damage, read and heed Martin's advice! It's vitally important to get everything straight, square, and level before doing anything beyond tack welding. We had the advantage of having several chain anchor points in the shop floor, so the chassis and the front frame clip could be anchored down and leveled, using screw-type jack stands that were intended for bracing travel trailers in a campground. Any error you build into the frame will be there forever- - - -"the gift that keeps on giving" handling and alignment-wise!
Have done dozens of these swaps and can state NOVA is the way to go. S10 too narrow, Camaro/Firebird/Trans Am too wide. Nova just right. Advise you level frame of donor car and write down the caster, camber, and anti dive angle. The camber will stay pretty much the same but the caster and anti dive can change according to the angle the clip is attached to the AD frame. To position the ifs the same as the factory axle and save lots of measuring run a pipe/bar/angle out from the top of the cowl with a cross bar that has two plumb bobs hanging exactly the width and wheel base as the straight axle. Hard to find but 1974 and older Novas had rear mounted steering boxes and 75 and newer have front mounted. Steering shaft easier on rear mounted.Pictures are on a 49 Studebaker but procedure is exactly the same as an AD.
Plumb bobs were set up on the OLD STRAIGHT AXLE:
[img]https://i.postimg.cc/FYCNhXh3/IFS-front-clips-007.jpg[/img]
[img]https://i.postimg.cc/gxFBRM4Q/IFS-front-clips-006.jpg[/img]
Angle of top A-frame cross bar was obtained from donor with frame level and attached to truck with its frame level, this is anti dive angle and keeps control during hard braking.
[img]https://i.postimg.cc/xNPqRpM5/IFS-front-clips-002.jpg[/img]
Evan
My Camero stub seems compatible. A friend just acquired a project 3100 on an S-10 frame , it looks too narrow to me.
I have observed the same. Virtually all S10 guys run wheel spacers to get their wheels out far enough. And Gen II Camaro guys are limited in their wheel selection due to excessive width.
1951 Chevy Panel Truck
Curmudgeon
Curmudgeon
Agree with Evan. Attached is a truck I looked at that was for sale locally. A Camaro sub was used. I took it for a test drive. It rode like a standard 60's/70's truck with IFS....comfortable with a roll in the curves. The front tires rubbed the fenders if you hit a dip or pot hole. It definitely needed narrower tires in the front. The second picture is a shot taken of a photograph and the image is not very clear.
Insomniac
Insomniac
You could leave it as is and simply bolt on a anti-roll bar. Big improvement in handling for a relatively small cost.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Why have a hassle with a Camaro/Firebird clip when a Nova FITS. The all red AD has a Camaro clip with shorter A-arms. Fits fender nice but the shorter arms required coil springs with a higher rate so rides rough. The red/black AD has a Nova clip that fits like a glove and rides and drives great.
[img]https://i.postimg.cc/hXR2fJ13/truck-roll-pans-clips-010.jpg[/img]
Usual way a Camaro is grafted to AD frame. The entire stub is used to give additional strength to a joint of mismatched widths.
[img]https://i.postimg.cc/yWJjjhfb/truck-roll-pans-clips-008.jpg[/img]
Grafted Nova stub inside view:
[img]https://i.postimg.cc/wtCMpppJ/truck-roll-pans-clips-006.jpg[/img]
Grafted Nova stub outside view:
[img]https://i.postimg.cc/68TC6tD1/truck-roll-pans-clips-007.jpg[/img]
Evan
''Cause I didn't have to pay for the clip.
