| | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | I have a chance to buy a 62 C60. It appears to be a nice truck but 2 things concern me:
It has air over hydraulic brakes. I heard from someone this is not a desirable feature. What is the downside to these? Also, are parts still available for the system?
It also has independent front suspension. I have only seen one other truck with this setup, and have no idea if it is a problem. I suspect if it was very successful, they would have continued with it, but there has to be very few around that I can tell. What are the problems with this setup?
Thanks for any help. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I know of no problems with the torsion bar front suspension. I had a 62' GMC with it and used it a lot for several years w/o any problems at all. Sure wish they still made those good old V6's.
The brakes should not be aproblem at all either. Be sure to keep the water out of the system by regular draining. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | GM dropped the torsion bars after 3 years because they were prone to break & the front end would drop way down. They had many lawsuits over them. I amagine if they havn,t broke by now they probably never will.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I had a 1960 Chevrolet LCF L80 series, road tractor. It had the Torsion Bar front suspension. Sweetest riding "Big Truck', I've ever owned. It had power steering, & full air brakes,and it was carrying a big block 348. I also had a 1964 Chevrolet LCF L60 series, that was air/over hdraulic. I had no problems, with this truck either. I especially liked having another truck, equipted, with an air compressor. Any big truck repair center, should be able to locate parts, for these trucks. A Chevrolet Parts Catalog, for these years,with part numbers, will always give you an advantage, when parts hunting. | | |
