0 members (), 100 guests, and 0 robots.
Topics128,151
Posts1,057,000
Members48,460
#1410418 05/19/2021 3:15 AM
Chief Bottle Washer
Chief Bottle Washer
Hello gang,
Can you please identify this carb on my 261?
I’d like to order a kit for it, but it appears different from the Roch-B of my old 216.
I’ve looked at the VIRTUAL MUSEUM OF CARBURETORS, but with no metal tag go off of, I’m in need of a starting point. Plus, the added mess of unknown shizzle below
the base, at the manifold has me scratching my head...
Many thanks!
Jim
Insomniac
Insomniac
Rochester B with a governor.
See section 0 sheet 7 of the factory assembly manual.
I was curious as to how the governor works. The shop manual has a description:
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0675.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Chief Bottle Washer
Chief Bottle Washer
Many thanks!
Curmudgeon
Curmudgeon
Air cleaner for a 6000 series with PCV option. Nice.
Pictures to help determine if you have the 59 261 carburetor.
