2 members (baldeagle, Hotrod Lincoln), 73 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1410070 05/16/2021 12:15 PM
I have a 327 in my 58 and would like to get a smaller engine for it.
I have a 700r4 in wait , what are good options....? LS swap 235 or larger original engine.
thanks
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer #1410076 05/16/2021 1:24 PM
I think a 235 came in the 1958 trucks. Is the 327 worn out?
An LS swap can be quite costly, depending on your time and skills. In my area of SC, folks want $1000 or more for a 200K mile 5.3.
Tell us more about your driving plans and skills.
Guitplayer #1410091 05/16/2021 3:27 PM
H Online: Content
If you want to stay "period-correct" a 283 would be a drop-in swap, assuming you can find one in good running shape or are willing to build one up from scratch. A 30 year newer option would be a 305- - - -which is basically a 265 with a 350 crankshaft. Lots of torque and relatively better gas mileage than a 327, and parts such as blocks and cylinder heads are much more available since that engine was used through the late 1980's at least. A 3rd. generation inline six such as a 230, 250, or 292 will bolt up to your transmission since they all have the V8 bellhousing bolt pattern, as well as a bunch of V6 engines. S-10 trucks tan a V6 with a 700R4, and if you don't want to go with the throttle body fuel injection, there are lots of intake manifold and carburetor options possible. You've got a big variety of options- - - -"Ya pays yer money and ya takes yer choice!"
Hotrod Lincoln #1410108 05/16/2021 6:56 PM
I would like to stay period correct with a little less horsepower and
better gas mileage. A 250 or 292 . The 327 feels like too much to me.
But what V6 engines are available matching my bell housing + 700r4 ?
thanks!
~ BD.
Guitplayer #1410109 05/16/2021 7:01 PM
Crusing in the Passing Lane
Easiest fix, replace the throttle return spring with a stronger spring!
Ed
Guitplayer #1410112 05/16/2021 7:20 PM
Riding in the Passing Lane
You will have to save a lot of gas to make up for the engine swap. Put that 700r-4 behind the 327 with a super tune up & you will get a nice driving truck & about as good of gas mileage as these old trucks can get.
George
1972 Chevy c10 Cheyenne Super
Guitplayer #1410124 05/16/2021 9:05 PM
Moderator, Electrical Bay
You also could swap to a different rear end. Find a 3.42 rear or 3.42 ring/pinion for the rear end you have (if that ratio is available for it). That is one of the best rear end ratios for the 700r4. Good luck.
~ Jon
Guitplayer #1410128 05/16/2021 9:57 PM
Thanks fellas!! Lots to think about. 327 been gone thru and I`ve adapted it pretty well
to the truck. Just a beast. I`m hoping the 700r4 will make it more of a cruiser. Quiet it
down some. I plan on running a new
exhaust system with new hooker headers. 2 1/2 inch pipe(2inch now) and move it to the
rear. Side exhaust now.
~ BD.
Guitplayer #1410129 05/16/2021 10:31 PM
Sir Searchalot
Sir Searchalot
The 327 is just a SBC, I think we don't really know what you mean by it being a "beast". Anyway, a 700r is a great choice. The Lokar floor shifters are really neat. Check that out.
As you may know, the pic you show are not headers, they are manifolds. You really don't need those. You have them already. If they are "better"/bigger, wouldn't they just add to the "beast" effect? Not getting the goal with those? You will gain +/- 1HP with what you plan. Maybe just straighten out the tail pipe design to run out the back. Which will add backpressure bends. smile <<<<<<<<<<<< mostly a joke everybody.
"Who draws the crowd and plays so loud"
Guitplayer #1410133 05/16/2021 11:00 PM
Former Workshop Owner
I ran tailpipes out the back of a '67 Chevelle I once had. It made a drastic difference. It was almost too quiet. I was much younger then. grin
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Guitplayer #1410135 05/16/2021 11:25 PM
Love the 700R4...run it in my 37 pickup and my 52 panel which had a reman 305 and 3:42 or maybe it was 3:48 gear from Yukon. The 37 is a hot rod and loves the 700....but the panel also loved it. The 700 ratio's which I have forgot are good and the overdrive is fantastic.
I'm with bartamos on the headers. Unless you want some eye candy you wasting your money......and some of them also make it louder in the cab.....just my .02
Guitplayer #1410158 05/17/2021 1:41 AM
guitplayer That is a nice cruiser,can't think you'll be sorry on that 327 it wont have much load but will provide power when you need it.
J Lucas #1410159 05/17/2021 1:44 AM
Jlucas Quiet is OK that way you can think !!
fixite7 #1410167 05/17/2021 2:43 AM
Quote
Sometimes I think too much. grin
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
Guitplayer #1410183 05/17/2021 10:55 AM
The headers in the truck now , won`t accept the larger pipe diameter.
I guess the beast part is alot of power. That might be better used with an auto instead of a manual 3 speed.
Id like better gas mileage and no threat of tickets. Quiet performance would be ideal.
I wanted to thank you guys for all the help and advise. I can do some things
with the truck but I have limitations. I`ll keep you guys posted!
~ BD.
Guitplayer #1410191 05/17/2021 12:34 PM
The 700R4 will help some with mileage, but the 235 and 283 didn't really do that great on fuel in these trucks any way due to the rear gears.
My 235 with three speed and 3:90 gears would get about 15 to 16 mpg on fuel, and 55mph was comfortable in it.
My 350 (fuel injected with 4L60E ) and the stock 3:90 gears now gets 20 mpg at 70 mph. Plenty of get up and go past that if I want it.
So don't really think you will help yourself going to a smaller engine. The 327 is a great engine and I bet with the 700R4 behind it your fuel mileage will increase.
Guitplayer #1410249 05/17/2021 7:17 PM
If you need a place to put that 327 after you get it out, you can always send it to me! grin
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Roy Rodgers #1410254 05/17/2021 7:52 PM
Thanks Roy, I`ll try it out
~ BD.
Guitplayer #1410259 05/17/2021 9:28 PM
Hey you guys think 2 1/2 inch pipe traveling the length of the
truck would be better than 2 inch ?
~ BD.
Guitplayer #1410268 05/17/2021 10:47 PM
Rams Horn exhaust manifolds with 2" pipes and stock mufflers is what I'd run. Take the pipes straight out the back so you don't get road reverberation noise.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Guitplayer #1410676 05/20/2021 8:35 PM
Sir Searchalot
Sir Searchalot
The 3.90 is a truck/load haulin/50-55 MPH rear. No matter how you spin it's pinion, it's still 3.90:1 ratio. With all you are doing, that needs looked at.
Guitplayer #1410681 05/20/2021 9:25 PM
H Online: Content
The manifolds in your photo that do not have stiffener struts between the ports are notorious for warping after a lot of heat/cool cycles and putting tension on the attaching bolts. if they're ever unbolted from the heads they spring inward, and can't be reinstalled without a LOT of prying and possibly cracking. Later versions of the same manifold had a 1/2" square strut cast between the ports to prevent the warp. BTW, dyno tests I've run using that style of manifold have outperformed a bunch of tube-type headers, especially in the low and mid-RPM ranges.
The 4.3L Chevy V6 used in the S-10 trucks with the 700R4 transmission are plentiful and cheap, if you're determined to replace the 327 with something else. That would be sort of like throwing out a good Sirloin steak and eating a hamburger, though!
Hotrod Lincoln #1411200 05/24/2021 6:46 PM
...if you're determined to replace the 327 with something else. That would be sort of like throwing out a good Sirloin steak and eating a hamburger, though!
Man after my own heart.
