7 members (Gdads51, TUTS 59, Buckeye998, Robert Crandall, Greg_H, 2-Ton, 1 invisible), 362 guests, and 4 robots.
Topics128,162
Posts1,057,041
Members48,463
Can you guys please post some pics of your interior rear view mirror and include how it is mounted, ie screwed through trim, etc?
Many thanks in advance.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
This is from my '56 3100.
~ Cameron
1956 3100 Task Force
Follow the build in the DITY
Thank you guys so much for these pics!
I am scratching my head now, as a guy at Carlisle sold me a mirror with what is basically a 3 hole mounting bracket, which is different from what you guys are showing in your pics! I will get a pic of what I bought, and post it, but it leads me to believe that he may have sold me the wrong part.
This is what he sold me:
https://www.classicparts.com/1955-59-Inside-Mirror-Bracket-Chrome/productinfo/57-010/
Only difference is he sold me an OEM painted one, not chrome. He seemed to be very knowledgeable, so, which one is correct?
I honestly have no idea if mine is correct or not. I hope it is, but it's way different from the one you posted. I'm sure someone with more knowledge on here knows.
~ Cameron
No worries, I just found the difference very interesting!
AD Addict & Tinkerer
I would think that what you bought is correct. MiraclePieCo’s is from an AD truck. Polarbeard’s look like a generic replacement. If it mounts correctly to the three holes, more than likely, it’s correct.
There has to be more TF ‘bolters out there to confirm.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks Phil, that's actually exactly why I'm asking- mine currently only has one hole, but I can't tell if that is because the other bottom 2 are supposed to go into trim or something? I'll get a pic of the area in my truck.
Thanks!
Here is a picture of a '55 suburban mirror. The two bottom screws go into the sheetmetal, the top screw must go in some trim or headlined. It's just hanging out there.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Thanks!
Well I will have to post a pic, but I don't have the lower 2 holes in my sheet metal. An interesting mystery!
Here is the pic of the [2] holes on my truck. Note that they are on the vertical piece, not up under the lip by the glass. Maybe it was meant to be more like polarbeard's?
I also have no clue why another piece of metal was welded to the left of the holes, and, something must have once been mounted where the driver sun visor belongs.
V
V Offline
What does the mirror in a 51 supposed to look like?
Advance Design Newbie.
Leo Offline
Moderator
Moderator
I don't have my 1953 panel anymore but the interior mirror was mounted on the windshield divider strip, second hole down.
The mount screws to the center windshield dividing garnish moulding.
Phil
Project Journals
none in my 64 C30 panel, only side mirrors
Wylie johnson
Just mount it to the windshield. Unless you are going concourse. If you get it wrong it can be moved by heating it the glue will release. I have moved mine a couple of times with no problems.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
