9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible), 120 guests, and 2 robots.
Topics128,119
Posts1,056,313
Members48,439
#1408191 05/01/2021 6:15 PM
I just realized that the water drain would be releasing water onto the rest of the engine, like into the PVC valve.
Wondering what others do there?
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
Year, make, model of truck and engine?
What water drain are you referring to?
P Online: Content
If you are referring to the cowl vent drain pipe then the original from factory has a slight angle to the drivers side of the engine compartment to keep from dumping the water onto the engine. Can provide a pic later today if desired.
1952 Chevy Pickup Truck
P Online: Content
52 Chevy 1/2 ton
That vent/scoop might still drip water onto the engine/valve-cover? That is especially fatal with Chevrolet Truck valve covers (engines) that have slits/holes in the top. A very poor/dangerous design.
For the sake of overkill and for complete drainage-safety, I have that hose/tube angled away from the driver's side, AND, I have a hose-to-hose tube-fitting for an extension hose that runs below the upper-lip/top of the oil pan. I remove this extension at shows.
P Online: Content
Maybe, strongly believe this is factory. Now, this truck has only seen rain (light) twice in the past 25 years of ownership.
I bought a new rubber gasket for my '48. That seemed to seal very well.
[img]https://www.stovebolt.com/ubbthread...C379AF4-CFAB-41CC-9382-9C225D547AED.jpeg[/img]Thanks, my truck does stay under a shed but I’ll see if I can extend it & to the side. I tried to post a picture but it never went through.
The reason I noticed was that today I coul not open the vent. WD 40 in the handle lock notches piece.
glennj3 #1408279 05/02/2021 11:35 AM
AD Addict & Tinkerer
Glennj3, your drain is too short. The factory replacements are quite a bit longer. Here’s one from Classic Parts and there really cheap. [LINK]
Phil
Project Journals
Stovebolt Gallery Forum
Those sites did not work. I used a water hose that slipped into the present hose. I may put a clamp on it.
Thanks!
