2 members (Steelonsteel, Wooley), 141 guests, and 2 robots.
Topics128,167
Posts1,057,020
Members48,458
Hello,
I am trying to find any reference photos as to how the original headlamp junction block was secured ( more so the location) in the engine compartment of the truck but I cannot find any information... Any help would be appreciated...
Philippe Jeanneau
If I recall correctly, the original junction block was secured to the inner fender with 2 unique looking rivets.
Lots more pictures
Philippe,
1939 was the last year for bulb/reflector type headlamps on a Chevy. The truck harness would not have used a junction block because the wires would have reached the lamp with a 3 contact plug which was a push and twist into the headlamp bucket. There is no application listed for a terminal block for a '39 truck in my '41 Master Parts list. The earliest truck listing is for 1940.
Someone with a 1940 truck can tell you where the block attaches.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
Hello Mike,
You're absolutely right, I got the set up mixed up with the 1940 year truck...I will change the heading of this topic and see if I get any bites from guys with 1940-46 trucks...
Philippe Jeanneau
9
9 Offline
Philipj look at inner fender for two holes the same spacing as block,and wire length works.
Karl j Townsend
Hello there,
I actually have a 39 model, so there are no holes on the inner fender... So, the case ends up being more of the actual location of the block so that it looks somewhat correct...
Philippe Jeanneau
Since it's not original to the truck, put it where you like it...no one is ever going to call you out on it.
My .02 cents,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Not sure if this is what you're looking for... this is where the blocks are on my 40. RH and LH side are in the same location
1940 1/2-ton
Low skill and low buck build
Follow in the Project Journals
In the dark of night, she's a looker.
Thank you 32vsnake, that is exactly what I wanted to know, the approximate area or location of the junction block...
Philippe Jeanneau
Thank you 32vsnake, that is exactly what I wanted to know, the approximate area or location of the junction block... Is your blue wire a ground wire?
Philippe Jeanneau
Correct... blue wire was acting as a ground
1940 1/2-ton
Thank you, still have the truck? Like to see a photo...:)
Philippe Jeanneau
lol...Yes I still have the truck, well most of it. smile It's currently being disassembled so I can go through it and fix some issues that required attention. Standard normal stuff, paint, electronics, suspension, drivetrain
last week vs this week
1940 1/2-ton
Beautiful machine, paint looks great...
Philippe Jeanneau
