7 members (55shaker, Tim Canfield, moparguy, Hotrod Lincoln, Gdads51, Bill Hanlon, treegrower), 132 guests, and 0 robots.
Topics128,195
Posts1,057,380
Members48,469
I hope someone has an idea how to install the exterior chrome trim with the glass and its track installed. When I got the 1950 Chevy truck the trim had been part of the extra parts in a box so I didn't see it removed. The windows where in place. so there must be a way to install without removing the glass etc..any help is appreciated...Glenn
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Lower the window all the way.
Remove the interior window trim.
Pull the fuzzy window channel up and out.
Install the exterior trim.
Push the fuzzy window channel back in.
install the exterior trim.
As Carl describes, I will add don’t tighten anything all the way down until all the screws are in, the fit is tight.
