| | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I hope someone has an idea how to install the exterior chrome trim with the glass and its track installed. When I got the 1950 Chevy truck the trim had been part of the extra parts in a box so I didn't see it removed. The windows where in place. so there must be a way to install without removing the glass etc..any help is appreciated...Glenn
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Lower the window all the way. Remove the interior window trim. Pull the fuzzy window channel up and out. Install the exterior trim. Push the fuzzy window channel back in. install the exterior trim.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | As Carl describes, I will add don’t tighten anything all the way down until all the screws are in, the fit is tight. | | |
