0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Why does the parking brake in my '49 3600 suck? Literally everything in the rear brakes is new. I'm fairly certain that I have it adjusted properly since if I tighten up the adjustment just slightly, the brakes drag and get hot. The parking brake pedal travels all the way to the floor and will hold the truck on perfectly flat ground, but forget it on any kind of incline. It seems like it should engage somewhere midway in it's travel. Am I missing something obvious here?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Try this; after setting the parking brake, push on the regular brake pedal firmly. On my '51 half ton, it helps a great deal to add this step.
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Also where are you “making adjustments “. Secondly Two man job. While slowly engaging inspect each link in the system. I had a pulley midway that was shifting causing not as much cable movement as I thought | | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | There is a solid rod from the pedal to the rockshaft that is adjustable. I've adjusted that so the rockshaft travels equal distance both sides of center from brake released to brake applied at full pedal travel (with the cables disconnected). I then adjusted each cable until the brake just started to drag and then backed them off 1/2 turn. The service brakes were adjusted properly prior to any of this. It's almost like there's lost motion in the system someplace since the pedal is going to the floor, but everything is new and tight.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Im not tryin to be a jerk but... READ the manual. I JUST went through this. I was losing my mind laying on the floor adjusting the brakes to the max. I got it to just work on flat but wouldn’t hold a hill. Then i got online and read the manual at work one day and i just started laughing at myself. I had no idea about the eccentric bolt that adjusts the slack in the parking brake system. Heres the link. Hope this helps ya. Manual | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the drums have been turned and the shoes have not been arced to match, this will give you very little shoe contact, and the e brake will not work well.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Pre 68 Dave thats a great point. Never even thought of that.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Pre 68 Dave does make a great point (as usual). However, I also suggest that you carefully read the Chevrolet Manual on how to properly adjust the rod which goes between the pedal and the crossbar. There is a specific distance indicated between the hump in the cross bar and the crossmember. Also, the cable adjustments are to be made with the parking brake pedal depressed 1 1/2". Its all in The Manual. If you don't already have the manual, buy one. Online versions are fine for certain things, but I like the hard copy for careful, over and over reading.
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Thats why i linked the manual. Its a very specific adjustment procedure. Im the normal guy that does it my way then if it dosent work I scratch my head and reluctantly read directions. Well my parking brake sucked HAHAHA. Then i read the directions. | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Im the normal guy that does it my way then if it dosent work I scratch my head and reluctantly read directions. Well my parking brake sucked HAHAHA. Then i read the directions. If I am not mistaken, The Man Card bylaws specifically require one to follow your modus operandi. Failure to do so precludes one from being issued said Man Card, or retaining any previously issued Man Card.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I’ve put it off long enough. Shutting the truck off and putting in gear every time I want to get out is pretty inconvenient. It’s time to address my parking brake.
It certainly looks like it’s all there (crust level 11) but I’ve been reluctant to try it....assuming that something would seize in place and cause me a lot of grief. The hydraulic brakes are rebuilt and working just fine.
Squirt all the moving bits down with penetrating oil....work all the joints loose and just go for it? Replace cables first as preventative action? Or lube it up as it as and follow the shop manual procedure?
1951 3100
