1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1404881 04/05/2021 5:28 PM
So I am putting together the clutch and engine that is soon to return to its rightful place in my '53 3100. Even an amateur hopes to avoid the most basic misteaks. Regarding the fitting of the pressure plate to the flywheel, the good book says "Hand crank the engine until "X" mark on the flywheel is at the bottom." Darned if I can find any "X" mark on the flywheel. Just what does this "X" look like? Is it in the rear face of the flywheel, or on the edge, or behind the bolts? My eyes aren't that bad...
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Moderator, Electrical Bay
Hi Karl,
I have not seen the X mark on any of the flywheels I've owned and I always thought it must have been removed when the flywheels were re-surfaced.
~ Jon
So what is the purpose in having the flywheel in a particular position for assembly?
1953 Chevy 3100
1960 Volvo PV 544
Is it for putting the pressure plate back in the same position relative to the flywheel? That's important if reusing the pressure plate, but doesn't really matter when installing a new clutch. It's similar to reference marking u-joints on a driveshaft when reinstalling. The book goes on to say line up the "X" mark on the clutch cover with the "X" on the flywheel.
And isn't one purpose of the "X" to ensure that the pressure plate is attached at a particular location?
1953 Chevy 3100
1960 Volvo PV 544
Missed your post Kevin. Exactly my question.
1953 Chevy 3100
1960 Volvo PV 544
Maybe it is a zen thing?
~ Jon
As I said, it only matters if you're replacing the same clutch. The shop manual doesn't say anything about marking the flywheel and clutch pressure plate on disassembly, but if you're putting in a new clutch, then there's nothing to index.
Yes, Tim, I found the "X" in The Book, just not on The Flywheel. Kevin, I have a new clutch but am reusing the pressure plate. And thereby exerting my god-given right to ignore good advice.
1953 Chevy 3100
1960 Volvo PV 544
thumbs_up
It was a balance issue. If you want to duplicate it, take your pressure plate, pressure plate bolts and flywheel to a good machine shop. Have the flywheel resurfaced and then balanced. It may already be balanced just fine, but then the machine shop will balance the pressure plate to the now balanced flywheel and mark both for the installation. Yes its a couple of extra dollars to do but you get to confirm that the flywheel is balanced at least to factory tolerances, that the rotating flywheel pressure plate assembly is balanced so nice smooth motor.
Mike
Crusing in the Passing Lane
When inserting the input shaft of the trans. Into the clutch disc, if you leave the trans. in high gear, it will be easy to rotate the shaft to line up the splines by rotating the trans. output shaft with one hand while pushing forward with the other hand to get the splines to engage.
Ed
Sounds good, Mike. I wonder if this might have to do with the current vibrational issues of my 235. I 've got a guy I can call about the balancing.
1953 Chevy 3100
1960 Volvo PV 544
Organbuilder I remember seeing the X's but that was when we worked on em the first time ! Now they are seldom seen ,most mechanics just slap the pressure plate right on in there.So wouldn't worry about it, rebuilt is probably balanced anyway. Your new disc is probably balanced too!!
hh
