| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I checked the '51 350 this weekend...two of the six wheels are the standard 10-lug Budd 3-piece rims. The other four have the same center, but a one piece rim. All are 6.5"x20" rims. Does anyone have a clue what the one-piece rims are from? I'd like to find two or three more. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I was around truck wheels for many years & never saw anything like that. Are you shure they are not 19.5 or 21.5s. I dont see how you could ever get a 20 in. tire on a one piece wheel.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | My guess is that the wheel is a late 50s tubeless tire wheel probably a 22.5 X 6 wheel | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Maybe they're the widow makers, the split rim that splits down the center, Scott | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Ok...I know how to measure, and I know what all forms of split rims look like...these things are 20" solid Budd wheels. They have 8.25-20 tires on them, I double-checked with a tape measure, and looked all over the rims - no seams. They're odd, but they had to come from something. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Are you sure they aren't 2-piece split rims? They have a wide band running around the center of the rim right where the wheel center is riveted to the outer wheel rim. Other than that they look just like a 1-piece wheel.  | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | you are not alone GMCpanel. I have seen those wheels and tire size befor on a mid 70s chevy C60 not shure were thay came from, but thay were a one peice 20inch rim! | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | oldchevy...on a '70s era C60? I'll have to check that out.
Mike B...my family has trucks with both type of splits, so I know the type you're talking about...these things aren't split. It looks like we may have a lead, though. | | |
