| | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 5 Member | | Member Joined: Jun 2003 Posts: 5 | Hi guys. I have been a member here for quite a while but all I have been doing is quietly reading messages and not saying anything. Now I would like to ask a little help from the Big Bolt gang about my brakes. I have a '52 chev. 6403 that I have shoehorned a 350 with an Eaton 5 speed in and now that it is moving I have turned my attention to stopping. I have rebuilt all 6 wheel cylinders and the master cylinder. I blew all the old fluid out of the lines and purged with fresh fluid. I replaced all the bleeders with new ones and adjusted the brakes. I have been trying to get these bled for the last 3 days and I cannot get a firm pedal. If I pump them about 10 times it starts to firm up but that is about as good as I can get. When I pump the brakes I can hear the vacuum canister cycling so I am guessing the diaphram is good. I don't know where to go from this point. Any input would be GREATLY appreciated. Thanks :confused: | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Did you bleed the Hydrovac Booster first. | | | | | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | I haven't worked on a system with a hydrovac, so I can't help you there. When I put my 3600 on the road I had the same problem. The cure was to really adjust the brakes until I could not turn the wheel, then back off the number of clicks listed in the manual. If you have Huck brakes, you will have to do this for each shoe. I followed the instructions in the manual to a tee and viola! had great pedal. | | | | | Joined: Jun 2003 Posts: 5 Member | | Member Joined: Jun 2003 Posts: 5 | I did not bleed the booster first but I did bleed it. I have adjusted the shoes very close but, I don't have a shop manual with exact procedure protocol. Does anyone know if there is a procedure online anywhere? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hey Dave, Purchase a Chevrolet Truck Shop Manual,for your year truck. Everything you need to know is in there. I've been a Truck, & Bus mechanic for 23 yrs. now, but I still make it a point to have a Service Manual for everything I own. | | | | | Joined: Jun 2003 Posts: 5 Member | | Member Joined: Jun 2003 Posts: 5 | Hey, thanks alot guys. I appreciate the input. I have to leave town for a few days so, will get on it when I get back. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If your brakes pump up, it's usually an adjustment problem. Adjust your brakes, work your brakes, adjust some more, etc.,etc. It's a process but it's a must-do for safety's sake. Scott | | |
