9 members (Sjm, moparguy, SmalltownTRKGuy, Jman, baldeagle, carbking, walter74, Wooley, 1 invisible),
334
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 27 Junior Member | | Junior Member Joined: Dec 2004 Posts: 27 | On the later Big Bolts are the doors, hood, etc etc the same as the 1/2 to 1 ton body parts? Or are the cabs of these bigger vehicles actually bigger?
Thanks.
'63 Chevy c60 dump
| | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | The Hood & Doors are the same, the cab is close, but the firewall & floor panels are not the same as the light trucks. And I'll bet you have figured out that the front clip is not the same, other then the hood. If you had an LCF like my truck, then the hood would not be the same., but the doors are only with the front lower conrer cut off, the Green Door seen here came from a 1962 GMC 1/2 ton, I just cut off that corner and bolted it on. | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | PsRumors, Since you're in Cartersville, check out Alsobrook's Garage in Hiram. He has a 62 big truck out there with a 261 engine in it. Well, he HAD one - I haven't been out there in a year or so. He has lots of "Big Bolts" out there. 261s, 292s and 302s out the ying-yang!  George (the owner) is generally a nice old guy but just not the most personable person in the world. Hiram is only about a 45 minute drive from you and Alsobrooks is on SR 92 (the road you must take to get there anyways). Let me know if you need exact directions. They close at noon on Saturdays. -ftyler | | | | | Joined: Dec 2004 Posts: 27 Junior Member | | Junior Member Joined: Dec 2004 Posts: 27 | Thanks for the replies.
ftlyer, is that the place right on 92, use to be Griffins? If not directions would be good. Thanks.
'63 Chevy c60 dump
| | | | | Joined: Dec 2004 Posts: 1 Junior Member | | Junior Member Joined: Dec 2004 Posts: 1 | Jolly, I really like your LCF, neat truck. BTW what does LCF stand for? I am a member of your site (6500 GMC dump truck with 351 V6). I don't quite fit here  as my truck is a 73, but at least the transplanted 351 is pre 73. Anyway I figure I can listen and learn here. Charlie | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 |
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Originally posted by PsRumors: Thanks for the replies.
ftlyer, is that the place right on 92, use to be Griffins? If not directions would be good. Thanks. You know I'm not sure if it was formerly Griffin's or not. I can tell ya that it's on the left going south on Hwy 92 about halfway between Hiram and Douglasville. Lots of "big bolts" everywhere. And it's the only salvage yard on the left south of Hiram on Hwy 92. Hope this helps. -ftyler | | |
