2 members (1955 1 Series, Ponchogl), 329 guests, and 3 robots.
Topics128,163
Posts1,057,044
Members48,463
#140129 12/23/2004 5:21 PM
Junior Member
Junior Member
On the later Big Bolts are the doors, hood, etc etc the same as the 1/2 to 1 ton body parts? Or are the cabs of these bigger vehicles actually bigger?
Thanks.
'63 Chevy c60 dump
The Hood & Doors are the same, the cab is close, but the firewall & floor panels are not the same as the light trucks. And I'll bet you have figured out that the front clip is not the same, other then the hood. If you had an LCF like my truck, then the hood would not be the same., but the doors are only with the front lower conrer cut off, the Green Door seen here came from a 1962 GMC 1/2 ton, I just cut off that corner and bolted it on.
PsRumors,
Since you're in Cartersville, check out Alsobrook's Garage in Hiram. He has a 62 big truck out there with a 261 engine in it. Well, he HAD one - I haven't been out there in a year or so. He has lots of "Big Bolts" out there. 261s, 292s and 302s out the ying-yang! eek George (the owner) is generally a nice old guy but just not the most personable person in the world.
Hiram is only about a 45 minute drive from you and Alsobrooks is on SR 92 (the road you must take to get there anyways). Let me know if you need exact directions. They close at noon on Saturdays.
-ftyler
#140132 12/23/2004 11:35 PM
Junior Member
Junior Member
Thanks for the replies.
ftlyer, is that the place right on 92, use to be Griffins? If not directions would be good. Thanks.
'63 Chevy c60 dump
Junior Member
Junior Member
Jolly,
I really like your LCF, neat truck.
BTW what does LCF stand for?
I am a member of your site (6500 GMC dump truck with 351 V6).
I don't quite fit here frown as my truck is a 73, but at least the transplanted 351 is pre 73.
Anyway I figure I can listen and learn here.
Charlie
Low Cab Forward.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
Quote
You know I'm not sure if it was formerly Griffin's or not. I can tell ya that it's on the left going south on Hwy 92 about halfway between Hiram and Douglasville. Lots of "big bolts" everywhere. And it's the only salvage yard on the left south of Hiram on Hwy 92. Hope this helps.
-ftyler
