1 members (Wooley),
105
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | How many of us need the rubber Fender, & Step Pads, for our COE's. I met with a guy this morning that has made a mold for the Step Pads, & left with some of my Fender Pads to make molds from them. He is doing them in rubber as original, & bought a sample of the step pads with him, & I must tell ya, he did a good job with them, & I expect him to good a good job with the Fender Pads as well. I compared his Step Pads, with the ones I purchased from Jim Carter, & they are just as "Authentic". The Fender Pads should be ready soon. | | | | | Joined: Apr 2003 Posts: 7 Member | | Member Joined: Apr 2003 Posts: 7 | Thanks for the heads up Spanky...I need a set for my '52. I almost got a set from Jim Carter then found out they don't include fender pads.
'52 2-ton Loadmaster COE....... ( This Space For Rent )
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Spank. Are they gonna have the mounting studs ? | | | | | Joined: Feb 2004 Posts: 13 New Guy | | New Guy Joined: Feb 2004 Posts: 13 | Originally posted by spanky: How many of us need the rubber Fender, & Step Pads, for our COE's. I met with a guy this morning that has made a mold for the Step Pads, & left with some of my Fender Pads to make molds from them. He is doing them in rubber as original, & bought a sample of the step pads with him, & I must tell ya, he did a good job with them, & I expect him to good a good job with the Fender Pads as well. I compared his Step Pads, with the ones I purchased from Jim Carter, & they are just as "Authentic". The Fender Pads should be ready soon. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | M.T. they won't have the metal bracing, or mounting studs. They will be glue on type, as the step pads are. He said it would make them too expensive to include the metal. I guess, if a guy wanted to, he could remove the metal from the Fender Pads being replaced, & glue them to the new pads. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | i need a set spanky! i was getting ready to fab up everything out of treadplate aluminum. see if you can get a cost for us! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I'll keep ya posted,Koolkar. | | |
