2 members (Roxxstar, 1955 1 Series), 298 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
How many of us need the rubber Fender, & Step Pads, for our COE's. I met with a guy this morning that has made a mold for the Step Pads, & left with some of my Fender Pads to make molds from them. He is doing them in rubber as original, & bought a sample of the step pads with him, & I must tell ya, he did a good job with them, & I expect him to good a good job with the Fender Pads as well. I compared his Step Pads, with the ones I purchased from Jim Carter, & they are just as "Authentic". The Fender Pads should be ready soon.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thanks for the heads up Spanky...I need a set for my '52. I almost got a set from Jim Carter then found out they don't include fender pads.
'52 2-ton Loadmaster COE....... ( This Space For Rent )
Anonymous
Unregistered
Anonymous
Unregistered
Spank. Are they gonna have the mounting studs ?
Quote
M.T. they won't have the metal bracing, or mounting studs. They will be glue on type, as the step pads are. He said it would make them too expensive to include the metal. I guess, if a guy wanted to, he could remove the metal from the Fender Pads being replaced, & glue them to the new pads.
Spanky Hardy
1950 GMC 250 1-Ton
i need a set spanky! i was getting ready to fab up everything out of treadplate aluminum. see if you can get a cost for us!
I'll keep ya posted,Koolkar.
Spanky Hardy
1950 GMC 250 1-Ton
