2 members (Hotrod Lincoln, mo2cyl), 380 guests, and 5 robots.
Topics128,158
Posts1,057,025
Members48,460
#1400232 03/06/2021 2:52 PM
Hi folks,
If anyone has replaced a two speed auto with a three speed turbo trans, I am curious if the original column can be used. I remember doing a 57 Chevy and Danchuk had a three speed indicator to fit the original column. If anyone has any experience with this please drop me a note!
Thanks again!!
3B Offline
Hy Grandpa C., please remember to tell us what year and size of vehicle your are asking questions about.
So, I have been looking for a 60-66 K10/K20 and not had a lot of luck. My thought now is to find a 2wd 60-66 long bed Fleetside and swap that body onto a later Suburban 4x4 chassis. I would really like to keep an auto trans in the Suburban BUT, I'd also like to keep the 60-66 interior looking as stock as possible. So, i'd really like to use the original 60-66 auto column, hence wondering if anyone has actually done this and how.
I swapped from a Pontiac two speed to T400 and a T350 in two different '65 Pontiac Tempest's. The column shifter worked in both cars, first gear was off the indicator, second was about right where 1st was, and high gear was right were D was. Your truck will be similar.
H Online: Content
Are you running a V8 engine or a six? Putting a TH 350 behind a 235 requires a pretty pricey adapter plate and a modified flex plate, since that was never an option from the factory. A 350 trans and a V8 will bolt together, but it might require a little creative drilling or flex plate swapping to make the torque converter bolt up.
Joe, thanks for the reply! That makes me more confident my plan might actually work. I may shop for a three speed indicator but I would be happy with the arrangement you had with the Pontiac.
Hotrod Lincoln, Definitely running the V-8!
Thanks to both of you for your thoughts,
George
