0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#139993 11/08/2004 2:08 AM
Apprentice
Apprentice
the 48 im rebuilding doesnt have a brake booster. what is a good one to use thats compatible with my original master cylinder. i can run the necessary vacuum lines. but what vehicle would make a good donor. thanks chris eek
I've done this too. I took a 75 3/4 ton Chevy truck booster and made a bracket to mount it under the floor in the original position. I put a 66 Pontiac Catalina dual drum brake master on it to have the extra reliablity of a dual master. The fab work consisted of making an adjustable rod between the pedal level and the booster and replumbing the brake system. Also making the mounting bracket involved a little creativity, but nothing too difficult. Then all you have to do is run your vacuum line and bleed your brakes. This also makes your truck much more enjoyable to drive,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
