7 members (Shaffer's1950, Southerntruck, Gdads51, John Dlugos, FAST55, TexasJim50, F100Ranger), 154 guests, and 1 robot.
Topics128,132
Posts1,056,378
Members48,441
is ther a template as where to drill the holes for the master brake cyclinder on the firewall of a 51 chevy 3100
Curmudgeon
Curmudgeon
I'm not trying to be a smart guy.
Since the original was mounted below the floorboard I think the correct answer would be, "it depends on what brand/type/manufacturer master cylinder you wish to mount on the firewall". To me, modifying brakes and steering on these old trucks need to be done professionally or at minimum buy a kit from an established and well known parts provider. I don't want to be the one to give advice that could lead to someone getting harmed or sued.
thanks buoymaker
You may want to position the pedal assembly where you like it and doesn't interfere with the gas pedal, steering column, or contours on the firewall. Then drill a reference hole to see where the master sits and reposition if it interferes with anything in the engine bay.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
thank you
Just curious to why you are moving it up to the firewall?
Here is one from POL (Performance Online). Keep in mind that this is specific to their brake kit and may not work for yours:
1951 Chevy Panel Truck
Crusing in the Passing Lane
Miracle,
I put one of these on my 55.2, had to modify it some for my specific application. Workmanship is poor, but it will work.
One can cut the cross shaft and use the pieces to move the pedal left or right and weld it back together if the fit isn’t perfect.
Your picture shows a hydrovac but a hydro boost fits too, tell them when you order it.
Ed
