6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#1396954 02/12/2021 4:58 PM
I finished painting my transmission and water pump. This was my first time painting an epoxy primer, base and clear automotive paint. It came out nice. I did a lot of smoothin on it before paint for aerodynamic reasons. I used a Fuji 5 stage turbine paint sprayer. I felt the need to replace all the bolts with polished stainless steel ARP bolts. This is a built Tremec TKO 600 with mid-shift kit going behind my little 292 in my 53 1/2 ton pickup. Thank you for your time.
nice
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Pretty, yes, but aerodynamic? Not so much. You left all those fins on. wink
Fox Offline
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Moderator, Electrical Bay
Looks good. Is that a coffee maker on the floor? Painting that, also?
~ Jon
Nice, slick looking. Good job.
Holy Cow That's Nice!
-David
1953 2-Ton GMC
DARN NICE. WOW. New transmissions dont look that good. Ha
What type gun did you use
Gerald
54 Chevy 3100
Anybody can do nothing
AD Addict & Tinkerer
The OP stated what he used in his original post. “I used a Fuji 5 stage turbine paint sprayer.”
Phil
Project Journals
Stovebolt Gallery Forum
That is one impressive looking little 292!
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
