| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Anyone know what differential would be a good donor to replace a 53 chevy 3600 3/4 ton diff? I want the higher gears like 3.73 gears Anyone? Thanks guy's!! Elmo | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Might want to review tire size, intended use, engine, trans-direct or OD, etc. Ff 14 bolts have good ratios.
Ed
| | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | (Ff 14 bolts have good ratios.) Ed Pruss? What? | | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | Elmo,
I guess we need a little more information...Are you looking to change the entire rear axle, or just the center section. Either way there is a ton of good info pinned at the top of the tons o' fun page. maybe start there and then ask follow up questions. BTW, my 48 3600 has a 292, T-5 with 0.86 OD, a 2003 14 bolt rear axle at 4.11, and 28.5" tires. If I did it again, I would look for a 3.73 axle. The other detail is mine has a flat bed, so I don't have to worry so much about width, and getting inside the back fenders.
Jon | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Elmo,
Jon Thanks Jon, For the info on Griggs information in Tons o fun. I think I will have someone that knows what they are doing, Do this job for me. I don't think I I'd feel comfortable doing this myself. Elmo | | | | | Joined: Nov 1995 Posts: 5,711 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,711 | Elmo, If you check at the top of this (and every  ) page in the Stovebolt Forums, you will see a link for our Tech Tips section. Once there, you can scroll down through the many helpful articles to the "Axles" section to find an article on upgrading the 3/4 and 1-ton rear axle. The truck in the article is mine. With the 261 engine, 17-inch wheels and the 4.11 ratio, I can hold 65 easily. 70 MPH will be more fun with tightened up steering (:) ) or radials ... Before you get too crazy with ratios like the 3.73, you might want to be sure your other components are up to that. If you still have a 216 in your truck, you will not get the desired performance boost from a 3.73 -- the engine will be over loaded. From what I hear, the 235 does ok. The 261 is a nice combo with the 4.11 ratio, though (and taller wheels/tires). Before increasing your cruising speeds, please ensure your brakes, steering, tires, etc are up to the increased demands of higher speeds. Finding the center section/3rd member for the HO52 Eaton axle is getting harder, but not yet impossible, and replacing yours with another with a more desirable ratio is far simpler and easier than switching out the whole rear axle assembly. Read the article. Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Thanks John Milliman, My truck a 1953 Chevy 3600 3/4 ton truck has a 235 in it. 16 inch wheels. If I do find a 3rd member 4.11 ratio to replace the HO52 axle. will I be able to go at least 60 miles an hour?
Thanks Elmo.
| | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Elmo, your simple question opens up a lot of discussion possibilities. If you'd like to read a few past conversations on this issue go here and here. You'll see a lot of the same opinions and advice. Bottom line is if you have a good engine and can get comfortable with how our trucks sound (not quite like modern trucks) at their design max working rpm/speed then yes, you can run 60 very easily and safely with a 4.11 gears. Thisspeed calculator tells the tail. You can even run 60 with your stock gears if it's in good original condition (using 3,000 rpm as a max cruse rpm). "Good condition" meaning it's current condition compares favorably with the way it was when say, oh, 2 or 3 years old. Good Luck, RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | | | | | | Joined: Nov 1995 Posts: 5,711 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,711 | Um, yeah -- What Ron said ...
