4 members (Patina 54, sron48, Otto Skorzeny, FAST55), 114 guests, and 2 robots.
Topics128,034
Posts1,055,440
Members48,422
#1398944 02/26/2021 1:56 AM
Anyone know what differential would be a good donor to replace a 53 chevy 3600 3/4 ton diff? I want the higher gears like 3.73 gears
Anyone?
Thanks guy's!!
Elmo
Crusing in the Passing Lane
Might want to review tire size, intended use, engine, trans-direct or OD, etc. Ff 14 bolts have good ratios.
Ed
(Ff 14 bolts have good ratios.) Ed Pruss? What?
ASU Offline
Elmo,
I guess we need a little more information...Are you looking to change the entire rear axle, or just the center section. Either way there is a ton of good info pinned at the top of the tons o' fun page. maybe start there and then ask follow up questions.
BTW, my 48 3600 has a 292, T-5 with 0.86 OD, a 2003 14 bolt rear axle at 4.11, and 28.5" tires. If I did it again, I would look for a 3.73 axle. The other detail is mine has a flat bed, so I don't have to worry so much about width, and getting inside the back fenders.
Jon
Originally Posted by ASU
Elmo,
Jon
Thanks Jon,
For the info on Griggs information in Tons o fun. I think I will have someone that knows what they are doing, Do this job for me. I don't think I I'd feel comfortable doing this myself.
Elmo
62401
Elmo,
If you check at the top of this (and every wink ) page in the Stovebolt Forums, you will see a link for our Tech Tips section. Once there, you can scroll down through the many helpful articles to the "Axles" section to find an article on upgrading the 3/4 and 1-ton rear axle.
The truck in the article is mine. With the 261 engine, 17-inch wheels and the 4.11 ratio, I can hold 65 easily. 70 MPH will be more fun with tightened up steering (:) ) or radials ...
Before you get too crazy with ratios like the 3.73, you might want to be sure your other components are up to that. If you still have a 216 in your truck, you will not get the desired performance boost from a 3.73 -- the engine will be over loaded. From what I hear, the 235 does ok. The 261 is a nice combo with the 4.11 ratio, though (and taller wheels/tires).
Before increasing your cruising speeds, please ensure your brakes, steering, tires, etc are up to the increased demands of higher speeds.
Finding the center section/3rd member for the HO52 Eaton axle is getting harder, but not yet impossible, and replacing yours with another with a more desirable ratio is far simpler and easier than switching out the whole rear axle assembly.
Read the article.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks John Milliman,
My truck a 1953 Chevy 3600 3/4 ton truck has a 235 in it. 16 inch wheels. If I do find a 3rd member 4.11 ratio to replace the HO52 axle. will I be able to go at least 60 miles an hour?
Thanks Elmo.
Elmo, your simple question opens up a lot of discussion possibilities. If you'd like to read a few past conversations on this issue go here and here.
You'll see a lot of the same opinions and advice. Bottom line is if you have a good engine and can get comfortable with how our trucks sound (not quite like modern trucks) at their design max working rpm/speed then yes, you can run 60 very easily and safely with a 4.11 gears.
Thisspeed calculator tells the tail. You can even run 60 with your stock gears if it's in good original condition (using 3,000 rpm as a max cruse rpm). "Good condition" meaning it's current condition compares favorably with the way it was when say, oh, 2 or 3 years old.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
Sent you a PM
62401
Um, yeah -- What Ron said ... smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
