| | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | Drove the 4400 dumptruck this last weekend. Had an exciting moment when I went to stop and brake pedal went all the way to the floor. Parking brake on the driveline stopped me from heading down a hill. Backed up and parked it by the shop and took the master cylinder cover off an it was close to bone dry with plenty of rusty looking schmegma in it.
I topped it off, pumped the brakes a few times and it does stop now - (I know - it aint right, but I am using off road on mostly level ground for now)
At any rate, I am going to go through the entire brake system and bring up to snuff with new/rebuilt parts. A quick check of the catalogs I have proved the point mentioned earlier that these bigger trucks don't get much respect.
Can anyone give me the short and skinny on what I am in for on this project? Are rebuild kits available for the wheel cylinders? Brake shoes? Master Cylinder? Flex lines? | | | | | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Try these numbers at your NAPA store. These are out of the '88 "Older Model Vehicles" catalog; the newer book doesn't list some of these parts, but I just checked with the local NAPA store and they're still good numbers.
1-1/4" Master cylinder kit--#33
1-3/8" front wheel cylinder kit--#77
1-1/2" rear wheel cylinder kit--#147 if ring type cups, #195 if solid cups
flexible brake hoses, front and rear--#4497
Shoes, not listed. Get your cores re-lined through the NAPA store or at a clutch & brake supply house. If you can't locate someone in your area, get back to me and I'll give you some names & numbers.
Joe | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Joe - Your are da MAN!!! I pick up master cylinder rebuild kit, front wheel cylinder rebuild kits and flex hoses tomorrow at noon at the NAPA across the street from my office I'll figure out the rear wheel cylinders after I get them apart, but both are in stock in the Portland warehouse. Thanks! | | | | | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Glad to be able to help. If I can be of further assistance, just let me know. Joe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Ken, I just bought a set of rear shoes for my 2 ton at a very reasonable price from a guy on ebay. His ad says he has 3000 sets of assorted shoes so he may have more for the big trucks. The ad says contact him with requests and he'll put them on Ebay. Might be worth a shot. Ebay ad Charlie | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Joe - I just looked at your truck, beautiful 3/4 ton you have.
Charlie - thanks for the tip, I'll check it out.
Ken | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Ken ,most big cities have brake reliners who will take care of the shoes for reasonable cost,the hydraulic stuff can be found as the other mentioned. I've done a lot of big truck brake work, buy a wheel dolly for the dealing with the rear duals, a lot easier and saves the new seals from damage. When you're done with it, use it for other purposes or sell it.Follow the manual on the rear wheel bearing adjustment, the bearings get a heavy preload, around 60 ft lbs.And carefully inspect the rear wheel bearings especially if you drive it on roads, they are generally rust pitted.GM uses barrel shaped rollers, they can be tough to locate, but a bearing distributer can match up more common tapered bearings,probably.Brakes are fun, crude and the end result is very gratifing if done correctly. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would rebuild or replace everything, wheel cylinders, master, rubber lines, steel lines etc. I would reshoe your brakes over buying replacements. The new ones are bonded, not rivetted, giving longer life with better friction material. You wouldn't know how old replacement shoe material is or amount of asbestos it contains. Most places can get it done the same day unless they have to send them out. That's my recommendation, Scott | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Rebuild kits can be had most places, just a spring, two rubber piston seals and cups for outer cylinder. BUT most times you wish you could get the pistons too, but can't, and the cylinders I have done, never clean up the rust pits and are no good. SO, kit prices blown for no good reason. I have found some cylinders on Chevy Duty's site, usually the fronts, as they are same as rears on some 1 tons and such. Rears are usually double cylinders after 53 or so, and each diff, and harder to find. May need to try Obsolete parts in Wisconsin for them or ask around more. If you have the older one cyl. Huck type, easier to find those. Maybe Bow Tie Bits in OK? or somewhere down south there may have these. Carter's sometimes does, call them. Expect to pay $70 to $90 each maybe more now, been awhile since I've done mine. I get my shoes recovered locally at a brake parts shop. They clean and look like new with coating on them and all. About $25-30 each shoe last time.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Originally posted by GLPerry: ...the cylinders I have done, never clean up the rust pits and are no good. SO, kit prices blown for no good reason... ...sometimes you see interesting URLs in people's .sig files... | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The front wheel cylinder kits came with new pistons, springs and seals as did the master cylinder kit. (I didn't buy the rears yet till I figure out exactly what I have)
I was surprised at how much $ they were. The kits work out to about $24 a wheel and the hoses were $24 each as well. and the master cylinder rebuild kit was in the same ball park. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Joe Way: Originally posted by GLPerry: [b]...the cylinders I have done, never clean up the rust pits and are no good. SO, kit prices blown for no good reason... ...sometimes you see interesting URLs in people's .sig files...[/b]I needed a good laugh! Thanks Joe!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
