| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 451 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 451 | Anybody buy spring sets from General spring KC?? Stovebolt search brings up 1 post about disc brakes, their prices seem low for 46 1/2 ton spring sets... dont know if they have teflon spacers or not but at the price one could add it........ trying to figure if this is a good deal or will put me further from where i want to be
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I bought a front and rear set of springs from them for my 1972 Jeep Commando. Well constructed, perfect fit, fast shipping. | | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | Page 69 and 72 of the information kit for a 1946, https://www.gmheritagecenter.com/do...hevrolet-Trucks/1946-Chevrolet-Truck.pdf has all the information on springs. The deflection rate is the same as spring rate, 1" compression for every 100 lbs applied. 1946 1/2 has a 260 lb spring rate. Be sure to ask what the new ones have. The higher the rate, the stiffer the ride. | | | | | Joined: Sep 2020 Posts: 451 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 451 | Good info and to the point, Thanks to you both,
