4 members (Otto Skorzeny, Ponchogl, 2 invisible), 182 guests, and 1 robot.
Topics128,147
Posts1,056,805
Members48,454
#1396623 02/10/2021 4:25 PM
like most Im plotting and planing for warmer weather returns, and the truck in storage. new front fenders are top of the list, do I have to remove the hood or grill to replace them ? cant wait to dive into those stove bolts again (-:
woof359 Family 1952 3100 5 Window
Yup.....just raise her down ☺
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
There are many, many bolts which attach the fenders to the grill. Few of them are easy to get to.
Hope this helps...
I think it's like 6 or 7 bolts. You do have to get under the fender to access them.
I would like to be there with a video camera to record replacing a front fender with the grill in place. New cuss word combinations will surely be heard.
That would be an interesting video. But I'd suggest the proper procedure would be to remove the entire grille first, replace the fender and then replace the grille.
R&Ring a fender with the grille in place would be about the same as rebuilding a transmission with the engine and driveshaft still in place.
Yep. Clearly more than 6 or 7 bolts.
Then you have to contend with the inner fenders.
The only way to replace the fenders and have everything line up when you are done is to remove the entire front clip (excluding the hood), and assemble all of the parts loosely.
This process can be a very challenging undertaking. Keep in mind that the radius at the top corners of the grill will not likely match the radius of the aftermarket fenders. Metal work of the new fenders will probably be required.
I can help walk you through the assembly process should you run into troubles.
