Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (homer52, Otto Skorzeny, TooMany2count), 152 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
#1394734 01/28/2021 5:28 PM
Fox
Offline
Howdy,
On the LM7 (2002) it has a return line coming off the fuel rail back to the tank. I am getting ready to run fuel lines up to the rails from the tank. I will be installing a fuel filter between the tank and rail on the feed line line. My question is this: how exactly does the fuel regulator work? Vacuum off the intake? It runs it at 58 lbs, correct? I am curious because I don't want to install a frame mounted regulator/filter if I don't need it.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1394784 01/28/2021 10:19 PM
The pressure regulator works off of intake manifold vacuum. Most LS swaps switch to a returnless system and use a C5 Corvette fuel filter/regulator to mimize long fuel line runs, but the return style works just fine.
Pressure is something like 48-50 PSI at idle.
Fox
Offline
I don’t mind running an extra line. I can run what I have for rails, install a filter inline and be good to go. I have the pump in tank already.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1394939 01/29/2021 10:00 PM
I completely understand running what you already have. It sounds like it's going to work out just fine.
Fox #1396444 02/08/2021 10:34 PM
Yes the regulator is just vac referenced from the manifold. They are a very simple setup. I have run both the older style return and returnless. Either will work fine but for a stretched performance setup you will always be able to make power on a return style setup.
