5 members (DennisM, FAST55, G508, 2 invisible),
157
Mod | | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Howdy, On the LM7 (2002) it has a return line coming off the fuel rail back to the tank. I am getting ready to run fuel lines up to the rails from the tank. I will be installing a fuel filter between the tank and rail on the feed line line. My question is this: how exactly does the fuel regulator work? Vacuum off the intake? It runs it at 58 lbs, correct? I am curious because I don't want to install a frame mounted regulator/filter if I don't need it. | | | | | Joined: Sep 2020 Posts: 40 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 40 | The pressure regulator works off of intake manifold vacuum. Most LS swaps switch to a returnless system and use a C5 Corvette fuel filter/regulator to mimize long fuel line runs, but the return style works just fine.
Pressure is something like 48-50 PSI at idle. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I don’t mind running an extra line. I can run what I have for rails, install a filter inline and be good to go. I have the pump in tank already. | | | | | Joined: Sep 2020 Posts: 40 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 40 | I completely understand running what you already have. It sounds like it's going to work out just fine. | | | | | Joined: Jul 2019 Posts: 567 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 567 | Yes the regulator is just vac referenced from the manifold. They are a very simple setup. I have run both the older style return and returnless. Either will work fine but for a stretched performance setup you will always be able to make power on a return style setup. | | |
