5 members (MikeStone1953, Hawkman, Peggy M, Lostbuthaulinass, NJC), 75 guests, and 3 robots.
Topics128,057
Posts1,055,810
#1394506 01/27/2021 12:04 AM
A friend of mine just replaced a blown head gasket on his 235, and I strongly suggested he drain the radiator and install fresh Xerex green coolant. His 1951 half ton is all original. How many gallons does his Harrison radiator hold? Thanks.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
If you check the Oner’s Manual for a 1951 Chevy truck you will see that the total cooling system capacity is 15 quarts. If there is a passenger compartment heater the capacity is 16 quarts.
So you need 8 quarts (2 gallons) of antifreeze to achieve a 50/50 solution.
Rusty
Thanks Rusty for the answer and for the math! LOL I’ll text my friend that he needs to buy 2 gallons of Zerex.
Chuck
1941 Chevy coupe
Just helping with the math...lol
He'll need 2-gallons of Concentrate (add your own water to make a 50/50 mix) or 4 gallons of pre-mixed 50/50...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
and a good estimate of how much water is still in the block.
I would also pull the plug near the bottom of the block on the drivers side, and flush. Fill and run it with a cleaner and the heater on. Empty and flush again. Then fill with new coolant.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
