4 members (Ridgeback, Tinker5, carbking, 1 invisible), 169 guests, and 2 robots.
Topics128,195
Posts1,057,369
Members48,469
#1394007 01/24/2021 9:59 AM
O.K. I have a 37 Chevy truck. I bought it with a 327 engine, totally rebuilt. (4000k mi.) It gets 10 miles to the gallon. Has 4 barrel. I am thinking of installing a LS so I can get better gas mileage. Even tho I can afford gas, the low mileage bothers me. Anyone know how much gas mileage would improve if I installed Electronic ignition and EFI on 327? Thanks for any help. Daily driver.
Beebs #1394009 01/24/2021 11:01 AM
A properly dialed in carburetor, and by that i mean using an AFR gauge to jet/meter it for your driving situation, can approach an EFI in terms of fuel efficiency. It won't likely match EFI because it isn't a closed-loop system but it can be very good. Same with Electronic ignition. When running right, the old systems worked extremely well - modern electronics brought better starting, reliability, less maintenance, and lower emissions for the most part.
In short, I don't think you will gain that much fuel economy by putting modern electronics on a vintage engine unless your current carb is out of whack and you don't want to tune it.
tomctomc #1394010 01/24/2021 11:59 AM
Thanks. Appreciate your info.😎
tomctomc #1394011 01/24/2021 12:01 PM
So will a LS give better milage.
Beebs #1394013 01/24/2021 1:02 PM
I think it will because of the heads/flow design, but I have no experience with that swap to give an opinion
Beebs #1394015 01/24/2021 1:26 PM
Beebs,
I have a 2001 5.3 LS in my 49 Chevy pickup and I calculated it once and best I can remember it gets about 16-18 mpg. I'm runing a 350 Turbo with 273 gears all setting on 18" wheels.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Beebs #1394022 01/24/2021 2:43 PM
Hmm, it may be better to spend the money for gas than the expense to gain a few MPG.
What transmission are you running? Does it have overdrive? And do you know your rear end ration?
I have not checked my mileage recently but I'm running a hot 350 engine/4 barrel, with 700R4 tranny and a 2.73 rear end. I get 15 if I drive it with a somewhat light foot! It'll burn the tires but going down the road in overdrive she just purrs.
Beebs #1394026 01/24/2021 2:55 PM
Find someone who understands your carburetor: $100.
Replacing the engine: $$$$$$$$$$$$$$$$$$$$
Beebs #1394034 01/24/2021 3:27 PM
What is the rest of the truck like? Gear ratio, tire diameter, transmission type, torque converter, carburetor type, camshaft grind, all these are part of fuel mileage.
My '37 drops 3 or four miles per gallon if I drive over 65 miles per hour due to wind drag. 250 inline six, 3.08 gear, 28" tires, T350 with tight converter,
21 mpg@ 65 mph, even high at 55 mph.
Install a Quadrajet would be the first move along with HEI and a Air/Fuel ratio gauge.
Beebs #1394038 01/24/2021 3:58 PM
On a good day, downhill with a tailwind, a brand new 327 in 1962 might get 12-14 MPG. My father was the best carburetor man in several states around Nashville Tennessee, and that's the best he could do with them. I doubt if 50 years or so of use will improve that figure by much, no matter how expert your carburetor rebuilder or tuner is. The saying back then was "A 327 can pass anything but a gas station!"
Beebs #1394061 01/24/2021 5:38 PM
WOW 10 mpg again WOW. In the past I owned a 70 1/2 Z/28 Camaro with a LT1 350, T400 trans, 4:11 gears, 11:1 comp, Holley 780. GM rated it at 360 hp & 380 tq but NHRA rated the HP at 425hp.
Now with all that said I could get as much as 16 mpg if I keep my foot out of it. Sounds like your 327 has some problems. Something isn't right with your combo of Carb/s, Heads and Intake not matching or working together. I have had many SBC motors 283,302,327,350 slightly built and still getting in the neighborhood of 16 mpg range.
Ask a question if you need a answer!
Resting up on Mon-Fri from Sat and Sun.
panic #1394062 01/24/2021 5:45 PM
Yeah what he says :~)
Beebs #1394126 01/24/2021 10:55 PM
Former Workshop Owner
I'm with Alvin, I'd see what gear ratio you're running and go from there.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
olezippi #1394188 01/25/2021 5:24 AM
Whoa. 😎
Beebs #1394213 01/25/2021 1:12 PM
Crusty Old Sarge
Crusty Old Sarge
Like the others here, there are just too many unknowns. how "Hot" is your cam, what size 4 barrel, what heads, what ignition? All that before we get to the drive train, what trans, what rear gear ratio?
A good tuner can improve on your overall performance but it will only go so far. Most times we want great performance and MPG's, it can be done but there may be a compromise along the way. Your overall build should match what your expectations are, Hotrod, Cruiser or Stock?
I have a 68' 327 (very modified) with a 4 speed and 3:08 gears, the 3:08's are my compromise.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Beebs #1394565 01/27/2021 9:52 AM
10 MPG is too low. Something's amiss. Find it, fix it, then check your mileage.
Don't be like me when I was a kid: I swapped a whole new engine when my original just needed a tuneup.
1951 Chevy Panel Truck
Beebs #1394582 01/27/2021 2:24 PM
A big part of mpg is related to total gear ratio. For that you need to know ring gear/pinion ratio, top gear ratio and last but just as important, tire diameter.
Example
IF, you're running a 3.73 rear end and 26" tall tires with a non-overdrive transmission and going 70 mph your 327 is turning 3,374 rpm. If that were the case, 10mpg sounds about right.
Add a .72 overdrive to the above scenario and you're looking at 2424 rpm when running 70mph. Not only would things quiet down, you'd likely see a major mpg improvement.
This might help.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
Beebs #1394623 01/27/2021 9:11 PM
And we still don't know what carburetor you have...
Just a guess: no vacuum advance?
Beebs #1395484 02/02/2021 6:01 PM
Thank you all for your input. Much appreciated. I am not a mechanic. So if anyone. Is interested my final thoughts are these. The 327 is for someone who likes speed. So someone else can put it to good use. I and having done a engine swap. I have seen some listings with low milage , ls' for around $700.00 including tranny and computer. I can hear them run before purchase. The front springs will be replaced, etc, for smoother ride. Like most of you , I have saved some loot. This is where it will go. Thanks again.
Beebs #1395658 02/03/2021 10:39 PM
Wow. $700 with a tranny and ECM. You better buy em all. That setup worth 3 times that on this coast. And not talking low mileage either..... headscratch
