4 members (UtahYork, tclederman, Peggy M, 1 invisible), 68 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1392603 01/14/2021 1:59 AM
I posted a few weeks ago about my weak heater and replacing the 160 thermostat with a 180 version. Unfortunately, during the test drives, the gauge goes half way between the midpoint and the top end before settling down just over the mid mark (by this time I have the heater on full trying to help get the temp down). So I pulled the 180 thermostat and tested it; which showed it to be a 190 thermostat! I reinstalled the 160 deciding I could live with it here in Texas, but noticed that I now have a small leak from the core running into the cab. I guess the high heat/pressure might have opened something up (sorry this is such a long story). To finally get to my question, is there anything I can do to try to seal up the core? I ordered a new one online, but was told that it will not be here until mid january (maybe, he admitted that it is coming from China). Instead of waiting, what else can I try?
Thanks, Lee.
Oh, and it is the non deluxe version heater, just a recirc fan in the round core.
1956 Chevy 3200, 235 w/3 speed
LeeD #1392606 01/14/2021 2:13 AM
Well about the only thing i could think of would be to connect da heater hoses together temporarily. No heat, but no leak either.
Been there, done that.
LeeD #1392609 01/14/2021 2:42 AM
Send it off to this guy and let him fix it up for you. wink
LeeD #1392615 01/14/2021 4:38 AM
Bars Leak, Silver Solder, Blue Devil, etc. I've done a couple of "temporary" repairs with these products that ended up lasting the life of the vehicle.
1951 Chevy Panel Truck
LeeD #1392619 01/14/2021 6:02 AM
1 Offline
Back in the day that I wrenched for a logging company, each re-cored radiator got a quart can of Bars Leaks. Otherwise they would be leaking again in a month or so. Rough roads, don't ya know. Don't put a whole quart in a pickup.
1951 3800 1-ton
In the DITY Gallery
LeeD #1392629 01/14/2021 1:36 PM
I did the circle hoses trick so I am still driving at least. I could not find where it was leaking when I took it out (it looked like it was coming from inside) but I did not put air in it to try to pin point the location. If I can find the leak I will try my hand at soldering and see if I can fix it.
Lee.
LeeD #1392642 01/14/2021 4:08 PM
I had poor luck with having the heater core repaired by a local radiator shop. It didn't leak until the water got up to temperature and then started a small leak. Did this 2 times. Finally purchased a replacement core from Brassworks. I posted about it here https://www.stovebolt.com/ubbthread...rks_Recirculating_Heate.html#Post1011395
LeeD #1392647 01/14/2021 5:04 PM
I may have the same issues about it only leaking when hot. I just pumped it up to about 20 psi (in a tub of H2O) and it did not leak. I am going to reinstall it and see if the leak returns.
Lee.
LeeD #1392648 01/14/2021 5:11 PM
Chuck,
I just read your post on the Brassworks core; really nice! I’ll look into that if my original is still leaking.
Lee.
LeeD #1392734 01/15/2021 11:56 AM
I also did a brassworks in my 49 gmc with my LS swap and I give it 2 thumbs up 👍 👍. Mine fit great and work great. Mine runs at a constant 190-195 so its nice and toasty in there. Fan is “loud” on high but i keep it on medium and it heats perfect for me.
LeeD #1392758 01/15/2021 3:01 PM
I also went the brassworks route on my 55.2 3100.
Brian
1955.2 3100 Truck
LeeD #1393036 01/17/2021 2:18 PM
LeeD Well you might try the oldest trick in the book...a tablespoon of black pepper in the radiator LOL !Seriously that will work, however I hate to put dirt in the cooling system !!
fixite7 #1393379 01/19/2021 3:43 PM
Tricks like that are just a temporary “get ya home” fix. Its not something that a critical thinker would ever trust long term.
LeeD #1393395 01/19/2021 5:39 PM
It looks like I will need to replace the core. Driving to work yesterday I had not gone a mile when I looked to the floor and saw water already starting to pool up. Fortunately I have shut off valves on both hoses so I closed them both and stopped the leak. Unless the leak is at the connections, it looks like leak is worse. Oh, well.
