8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna), 154 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#1392900 01/16/2021 5:23 PM
Hello everyone
I have a 1950 GMC 1/2 ton. When I try to order parts from car quest or Napa they ask what series it is (for example FC101,102). I cannot Find a reference list anywhere where I can compare the VIN to a series. From the VIN I believe it is a 1300 or 9300 series truck. Wheelbase is 116”
Thank you
Rmcea #1392903 01/16/2021 5:31 PM
You have a Canadian GMC
Do you have metal plate on the door opening (between driver's-side hinge)?
What is your engine serial number (stamped/pressed into the block on the ledge to the rear of the distributor)?
You might want to also post your question on oldsGMC.trucks.com discussion board?
My engine # is C332586
Rmcea #1392935 01/16/2021 10:21 PM
Leo Offline
Moderator
Moderator
The Canadian light duty trucks had Chevy engines. The series would be 9300. 1300 were Chevy half ton trucks.
Rmcea #1392939 01/16/2021 10:35 PM
2 Offline
Only the 3 ton and up gmc seem to get a gmc engine in Canada or so I’ve been told
My 2 ton and 2.5 ton gmc both have a Chevy engine
-s
Rmcea #1392967 01/17/2021 12:45 AM
Could try telling them it's a chevy 3100. Seems like they're easier to find in napas database than the Canadian GMC's. Seems to work for me for anything other than engine parts.
Rmcea #1392969 01/17/2021 12:59 AM
You would have. 9300 if it was a half ton, 1300 is Chevy .I have a 54 gmc 9300 when I look up parts I look up using Chevy 1/2 ton .you truck came with a 216 most likely unless it was changed .if you need a shop Manuel there is a 54 gmc Manuel on kijjiji London for 20 bucks it is a Canadian version it would be different in some ways but if you truck has a newer 235 it would have it covered as well as the gmc engines in he bigger trucks
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Rmcea #1392970 01/17/2021 1:02 AM
Casting numbers on the engine are usually the easiest way to see what engine you have rather than the serial number ,at least on a Canadian truck
"The Journey"
Follow in the DITY
Rmcea #1392974 01/17/2021 1:16 AM
1950 Canadian GMC Chevrolet trucks are way down on this page.
1915 - 1972
It is a very long web page.
Rmcea #1392981 01/17/2021 1:50 AM
Here is a copy of the serial number explanation from the manual. I have the same page in my manual for 1948 to 52. old GMC Trucks . Your truck would be all Chev mechanically. Even the white on brown instruments are in Chev colours. Most cartalogs have listings using the US series numbers so I believe yours would be a 3100 in the catalog. I am curious which motor you have. I have the Canadian 216 with the short side cover.
1951 1 Ton Completed
Rmcea #1392988 01/17/2021 2:24 AM
Thanks for all your help
