7 members (Gdads51, Guitplayer, Donf, FAST55, papas52, DougH6100, Hanks custodian), 82 guests, and 2 robots.
Topics128,162
Posts1,056,950
Members48,458
Restorationist
Restorationist
hey all, im going to be buying a new firewall pad for the 48. my original is in to bad a shape to keep . my question is what are you guys using? is there anything like the original out there? im finding abs plastic and polyurethane.is there a rubber one like the floor mat? im trying to keep it as original as possible. chevs of the 40s has a fiber board one but they say its on back order forever. any help on this subject would be a big help. thanks.
1948 1.5 ton grain truck with pto driven dump bed.
[url=https://www.classicparts.com/searchprods.asp] -0 search on inner firewall
Inner Firewall pad/parts - most vendors' "cover" is ABS plastic
I got mine some time ago from Brothers trucks. Jute backing with neoprene rubber face. Pre punched holes. Was about$50. Worked out nicely. John
1949 gmc 1-ton
Restorationist
Restorationist
Thanks. I think the neoprene is what I’m looking for. It will be about the same thing the floor mat is made of. Checked their website and it is on back order. I’ll type that in as a Google search and see what comes up. Thanks again.
The originals were fiberboard with fiberglass insulation on the side facing the firewall. I think neoprene would sag unless it has some sort of reinforcement in it. I believe that the pad was stuck on with some sort adhesive as well as the pins going thru the sheetmetal. I scraped some of that adhesive off the inside my firewall before getting it sandblasted.
Restorationist
Restorationist
I will look out for sagging if I decide to go the neoprene route. Maybe a few extra clips at the top will help. I took a look at your pictures of your build . Nice job. That's a lot of metal work.
something I found on eBay similar to what you are looking for ?? check it out, eBay 323864530372. Mike
I bought mine from classic parts. Its got a felt style insulation on the back and the front is just a thin rubbery vinyl material thats smooth. I think it looks and works perfect when I was building mine to look factory. I used the jim carter floor mat with the insulation pad under it and I love the way it came out.
Restorationist
Restorationist
Looked on both eBay and classic parts and those are ideal for this build. Matched with the rubber mat and that will be just right. I will have to put classic parts on the list for another parts supplier. Thanks. .
Moderated
Moderated
I had good luck with LMC truck
Restorationist
Restorationist
I bought the one from classic parts with the rubber face. Seems like it will be a good one. I'll find out soon when I install it. I'll let you guys know how it turns out.
Moderated by  ndkid275, Phak1
