0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 46 Restorationist | | Restorationist Joined: Feb 2020 Posts: 46 | hey all, im going to be buying a new firewall pad for the 48. my original is in to bad a shape to keep . my question is what are you guys using? is there anything like the original out there? im finding abs plastic and polyurethane.is there a rubber one like the floor mat? im trying to keep it as original as possible. chevs of the 40s has a fiber board one but they say its on back order forever. any help on this subject would be a big help. thanks.
1948 1.5 ton grain truck with pto driven dump bed.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | [url=https://www.classicparts.com/searchprods.asp] -0 search on inner firewall Inner Firewall pad/parts - most vendors' "cover" is ABS plastic | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | I got mine some time ago from Brothers trucks. Jute backing with neoprene rubber face. Pre punched holes. Was about$50. Worked out nicely. John 1949 gmc 1-ton | | | | | Joined: Feb 2020 Posts: 46 Restorationist | | Restorationist Joined: Feb 2020 Posts: 46 | Thanks. I think the neoprene is what I’m looking for. It will be about the same thing the floor mat is made of. Checked their website and it is on back order. I’ll type that in as a Google search and see what comes up. Thanks again.
| | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | The originals were fiberboard with fiberglass insulation on the side facing the firewall. I think neoprene would sag unless it has some sort of reinforcement in it. I believe that the pad was stuck on with some sort adhesive as well as the pins going thru the sheetmetal. I scraped some of that adhesive off the inside my firewall before getting it sandblasted.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2020 Posts: 46 Restorationist | | Restorationist Joined: Feb 2020 Posts: 46 | I will look out for sagging if I decide to go the neoprene route. Maybe a few extra clips at the top will help. I took a look at your pictures of your build . Nice job. That's a lot of metal work.
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | something I found on eBay similar to what you are looking for ?? check it out, eBay 323864530372. Mike | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | I bought mine from classic parts. Its got a felt style insulation on the back and the front is just a thin rubbery vinyl material thats smooth. I think it looks and works perfect when I was building mine to look factory. I used the jim carter floor mat with the insulation pad under it and I love the way it came out. | | | | | Joined: Feb 2020 Posts: 46 Restorationist | | Restorationist Joined: Feb 2020 Posts: 46 | Looked on both eBay and classic parts and those are ideal for this build. Matched with the rubber mat and that will be just right. I will have to put classic parts on the list for another parts supplier. Thanks. .
| | | | | Joined: Nov 2017 Posts: 3 Moderated | | Moderated Joined: Nov 2017 Posts: 3 | I had good luck with LMC truck | | | | | Joined: Feb 2020 Posts: 46 Restorationist | | Restorationist Joined: Feb 2020 Posts: 46 | I bought the one from classic parts with the rubber face. Seems like it will be a good one. I'll find out soon when I install it. I'll let you guys know how it turns out.
