1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1392319 01/12/2021 2:41 AM
I found a 1970 C70 that was in a fire tires didnt burn but i just want it for parts mainly the brownie. I want it for my C70 the owner said he couldnt down shift it but just why i couldnt get out of him. How are they to shift ? The truck is priced write if you need alot of parts but not if the part i want isnt any good.
Old Doug #1392323 01/12/2021 3:02 AM
H Online: Content
I'll bet he didn't know how to RPM match- - - -most Brownies ARE NOT synchronized- - - -gotta shift them like a crash box! Slip the box out of gear without disengaging the clutch, rev the engine up until you can slip it into the lower gear, and drive on. The Mack Tri-Plex I learned to drive big rigs on had a 5 X 3 setup, and I could go up and down all 15 gears without using the clutch. There's no need to double clutch unless you just enjoy exercising your left leg.
Old Doug #1392328 01/12/2021 3:33 AM
He wants 2000.00 i can get a trans and driveshafts for under 500.00. I may go look at it.
Old Doug #1392338 01/12/2021 4:32 AM
Crusing in the Passing Lane
Make sure to get the remote shifter, linkage is easily made from EMT tubing. Find out the model number, too.
Ed
Old Doug #1392344 01/12/2021 4:55 AM
H Online: Content
It's fairly simple to make a Brownie shifter from the top cover of a trashed-out SM-420 4 speed transmission.
Old Doug #1392620 01/14/2021 6:11 AM
1 Offline
FWIW Ya gotta use the clutch on the road test for your CDL. When I upgraded from a chauffer's license to a CDL I didn't bother with the clutch and the examiner marked me off one point for each shift. I had to come back the next day and take the test again and pay the $75 again.
1951 3800 1-ton
In the DITY Gallery
1Ton_tommy #1392660 01/14/2021 6:44 PM
"I don't know how to do your job! But my book says you're doing it wrong!"
Old Doug #1392718 01/15/2021 4:41 AM
H Online: Content
I'd love to see that examiner drive a 4 X 4 transmission setup with an air-shifted Brownie a few miles and try to do it using the clutch for every shift! I doubt if the transmissions would survive!
Old Doug #1392725 01/15/2021 5:49 AM
Fox Offline
So I’m kind of highjacking this as my sm420 acts up like this. I can’t shift OUT of 3rd most of the time with the clutch. I have to have my revs just right, pull it out of gear with no clutch, downshift and carry on. It goes into 3rd beautifully, always. I’m guessing now I have a bad synchronizer? I thought it wouldn’t affect shifting out of a gear, just into a gear. I want to make it easier for others to enjoy the truck.
Help?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
