Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
Page 2 of 2 1 2
Thanks DoubleDingo. I'm taking Jerry's advice, I'm going to see how the 250 does. If I need to replace, my limited experience dictates the 230, since it will require no modifications.
1965 Chevy C10 Longbed Fleetside
Unconventional Thinker
You're welcome. From what I've heard about the 250, if it's tuned properly you should be happy with it. You can wake them up with some upgrades, but as with anything, it all depends how much you want to spend on it.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
10-4. I was all set for a 230 because I wanted all original but I can live with the 250 if it runs well.
Moderated
Moderated
Hot rod Lincoln. You stated in an earlier post that there was a way to swap a 305e to a SBC 350 in a 1966 k1000 with a Sm 420 tranny but the bell housing was rare and expensive. Can you tell me what bell housing to use and what model truck it was used in
Billypylot
The bellhousing I'm thinking of has the clutch throwout fork window on the passenger's side, and is used with the hydraulic master cylinder that combines brake and clutch functions in the same casting. I'm not sure that it was used as late as 1966. Does your 305 have a hydraulic clutch? That's the only V8 bell housing I can remember that was used with hydraulic linkage. If you have a regular manual clutch setup, any cast iron V8 bellhousing from the mid 1970's with the angled motor mounts should mate the transmission to the engine. You might have to get creative with some custom clutch linkage.
The 1960-1962 C10 trucks used a hydraulic clutch with the fork on the passenger side. The 1963-1972 C10 trucks have the fork on the driver side and they have a mechanical linkage. You may find that info helpful in your search.
Page 2 of 2 1 2
