6 members (qside, TUTS 59, Jon G, RdsLessTaken, 68ironhead, 1 invisible), 74 guests, and 2 robots.
Topics128,136
Posts1,056,430
Members48,441
#1390910 01/02/2021 3:09 PM
Is there any problems with putting 50 doors on 54 cab. Truck is 54 3100 5 window. Any problems with striker or latch location?
AD Addict & Tinkerer
The strikers are different on the 50 so changing them to the 50 style would be necessary. I don’t know if there’s any other mods you would need to do.
Phil
Project Journals
Stovebolt Gallery Forum
flattop49 #1394125 01/24/2021 10:51 PM
You shouldn't have an issue I used 49 doors on my 54 cab. However I used Altman Easy Latches so I could put electric locks in it.
1951/54
Basketcase
flattop49 #1394138 01/24/2021 11:52 PM
Or, if you want to use “original” latch/catch, use a pair from the same year/style.
There were at least two different styles between 47-55st.
flattop49 #1394144 01/25/2021 12:32 AM
First photo, 47-51 latch.
Second photo, 51-55 1st series latches (also fit 55 second series thru 62).
Phil
Project Journals
Another option is to use a Hagan vent window elimination kit on your 51 and up doors.
Evan
flattop49 #1396262 02/07/2021 10:10 PM
The recess in the cab is different where the strikers go I've never had a set close properly when mixing and matching. I was able to put 54 doors on a 48 but not the other way around. Altman or Bear Claw probably fixes that.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Moderated by  ndkid275, Phak1
