4 members (Otto Skorzeny, WICruiser, dwreills, 78buckshot), 45 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#1390243 12/29/2020 4:01 AM
Hello from Utah,
I am new to the classic truck world after finally picking up a classic AD truck. Well, I have found that my 1953 chevy 3/4 ton needs floors, kick panels, toe panels, cab corners and probably stuff I don't know about yet. I have looked around and found there to be several suppliers for patch panels but I want to make sure I get a good quality part so I am reaching out to anybody that can help me make an educated choice.
AD Addict & Tinkerer
The word on the street is they all come from China and more than likely the same factory. None of the panels fit perfectly and will need to be tweaked.
Phil
Project Journals
Stovebolt Gallery Forum
well darn it, I was hoping for "Made in the USA". oh well, take what you can get I guess. thanks for the reply.
There are a few patch panels that are USA made. I believe Jim Carter sells a few that are fabbed by Wheelwright Restorations. Inner Kick panels that I used, and inner rear cab corners that would work for the lower portion of the inner cab corner. I needed the whole inner cab corner so couldn't use that one.
I have used the made in Taiwan patch panels and they worked out OK. Just about every one of them needs to be massaged a bit to fit correctly.
Thats great news, thank you. 👴
Thanks to klhanson, I looked up Wheelwright Restorations located in Wheelwright Massachusetts and found an interesting youtube video on a tour of his shop and some of his work. [LINK] I warn you its quite long so get comfortable with your favorite beverage, but real interesting and very informative.
He also has a website.[LINK]
Phil
Project Journals
That link is to info about Wheelwright Restorations in MA (displayed on Rob English's oldGMCtrucks.com website).
Here is Ray Stanley's website. - parts are listed/sold here.
Call for prices.
He is a master "metal man" and he is a very nice fellow.
Key Parts or Tri Parts "patch panels" are the Best for 67-72 Chevys which is what I own (68 C10). Not real sure for your year (53) as I don't look for those years so I really don't know but Hey anything is possible. Good luck, and also my .02 cents is they all need too be "tweaked a little.
Ask a question if you need a answer!
Resting up on Mon-Fri from Sat and Sun.
Tri-Plus are some of the panels I've used. Also Sherman, but I believe they're all from the same source.
thank you all for the great information. I'll check out those places. Happy New Year!
