8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | Hello from Utah, I am new to the classic truck world after finally picking up a classic AD truck. Well, I have found that my 1953 chevy 3/4 ton needs floors, kick panels, toe panels, cab corners and probably stuff I don't know about yet. I have looked around and found there to be several suppliers for patch panels but I want to make sure I get a good quality part so I am reaching out to anybody that can help me make an educated choice. | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | The word on the street is they all come from China and more than likely the same factory. None of the panels fit perfectly and will need to be tweaked.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | well darn it, I was hoping for "Made in the USA". oh well, take what you can get I guess. thanks for the reply. | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | There are a few patch panels that are USA made. I believe Jim Carter sells a few that are fabbed by Wheelwright Restorations. Inner Kick panels that I used, and inner rear cab corners that would work for the lower portion of the inner cab corner. I needed the whole inner cab corner so couldn't use that one.
I have used the made in Taiwan patch panels and they worked out OK. Just about every one of them needs to be massaged a bit to fit correctly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | Thats great news, thank you. 👴 | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | There are a few patch panels that are USA made. I believe Jim Carter sells a few that are fabbed by Wheelwright Restorations. Thanks to klhanson, I looked up Wheelwright Restorations located in Wheelwright Massachusetts and found an interesting youtube video on a tour of his shop and some of his work. [LINK] I warn you its quite long so get comfortable with your favorite beverage, but real interesting and very informative. He also has a website. [LINK]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That link is to info about Wheelwright Restorations in MA (displayed on Rob English's oldGMCtrucks.com website). Here is Ray Stanley's website. - parts are listed/sold here. Call for prices. He is a master "metal man" and he is a very nice fellow. | | | | | Joined: Dec 2020 Posts: 49 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 49 | Key Parts or Tri Parts "patch panels" are the Best for 67-72 Chevys which is what I own (68 C10). Not real sure for your year (53) as I don't look for those years so I really don't know but Hey anything is possible. Good luck, and also my .02 cents is they all need too be "tweaked a little.
Ask a question if you need a answer! Resting up on Mon-Fri from Sat and Sun.
| | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | Tri-Plus are some of the panels I've used. Also Sherman, but I believe they're all from the same source.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | thank you all for the great information. I'll check out those places. Happy New Year! | | |
