2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | thinkin about using lokars trans mount emergency brake handle. im using the tall nostalga shifter. is anyone else using these.if so did you use the 15" or 11" handle......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | David I will be using a Lokar trans bolt on mount but will go back with the original foot operated parking brake. I know it would be easier to attach at the tranny but I wanted more foot space for a third passenger.
~Jim
| | | | | Joined: Apr 2006 Posts: 4 Junior Member | | Junior Member Joined: Apr 2006 Posts: 4 | david i use a lokar nostalgia shifter and a 11" hand brake and i am going to change it to a 16" because it feels to short. it works fairly well but if you can, use the original. it feels more correctly. i could not use the original because i change the frame and front end on my 56 truck. /a | | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | I am using the Lokar Nostalga shifter mounted to the tail of a Turbo 350. I Then mounted a original '37 park brake lever to the side of the shifter mount. It only took drilling a hole or two and the brake rod lined right with the truck mounted parts. It looks original and functions just as well. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | it seems that all the emphasis is on making adapters for the automatic to insatll a floor mounted e-brake handle. i have a pix of someone on here who made an adapter for a t-5 and i will try that. i would like a tall shifter for my t-5. it would seem as so many are using the t-5 that the aftermarket parts makers would catch on.  ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | David, We used the tall lokar nostaglic shifter and the 11" trans-mount e-brake. Worked out fine on our 53. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | thanks for the input, went to the nsra nats in louisville ky. thursday, bought the trans mount 11" and cables it was $240.00 . after checking lokars booth it seemed the right way to go.......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Dave, I have some photos on my site of the interior and the lokar shifter and e-brake. Coach Frank | | |
