1 members (1 invisible), 65 guests, and 0 robots.
Topics128,049
Posts1,055,740
#138902 08/01/2007 9:56 PM
thinkin about using lokars trans mount emergency brake handle. im using the tall nostalga shifter. is anyone else using these.if so did you use the 15" or 11" handle......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#138903 08/02/2007 3:49 AM
David
I will be using a Lokar trans bolt on mount but will go back with the original foot operated parking brake. I know it would be easier to attach at the tranny but I wanted more foot space for a third passenger.
~Jim
#138904 08/02/2007 10:08 PM
Junior Member
Junior Member
david
i use a lokar nostalgia shifter and a 11" hand brake and i am going to change it to a 16" because it feels to short. it works fairly well but if you can, use the original. it feels more correctly.
i could not use the original because i change the frame and front end on my 56 truck.
/a
#138905 08/03/2007 12:26 AM
I am using the Lokar Nostalga shifter mounted to the tail of a Turbo 350. I Then mounted a original '37 park brake lever to the side of the shifter mount. It only took drilling a hole or two and the brake rod lined right with the truck mounted parts. It looks original and functions just as well.
#138906 08/03/2007 11:12 AM
it seems that all the emphasis is on making adapters for the automatic to insatll a floor mounted e-brake handle. i have a pix of someone on here who made an adapter for a t-5 and i will try that. i would like a tall shifter for my t-5. it would seem as so many are using the t-5 that the aftermarket parts makers would catch on. ohwell ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#138907 08/03/2007 5:00 PM
David, We used the tall lokar nostaglic shifter and the 11" trans-mount e-brake. Worked out fine on our 53.
#138908 08/05/2007 6:50 PM
thanks for the input, went to the nsra nats in louisville ky. thursday, bought the trans mount 11" and cables it was $240.00 . after checking lokars booth it seemed the right way to go.......dave
1949 Chevrolet 3100
#138909 08/07/2007 3:21 PM
Dave, I have some photos on my site of the interior and the lokar shifter and e-brake. Coach Frank
