7 members (farmallb, Samantha, Opelika Tom, Oswald, Hanks custodian, 2 invisible), 79 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#138888 07/31/2007 2:08 AM
Junior Member
Junior Member
has any one here done this swap? my clutch housing has the angled mounts,is there a clutch housing that will fit that cross member and bolt to the 292 engine?
thanks for any info
#138889 07/31/2007 3:19 AM
V-8 bell housing from a '55 to '67 (I think) Chevy pickup. I'm not sure what clutch issues you might encounter, except to not some of those years Chevy used a hydraulic clutch.
The bell housing used on sixes starting in '63 and through the same year ('67?) will also work with the same clutch caveat.
The crossmember has those angled mounts starting in '54 and does make this swap easier.
#138890 07/31/2007 4:05 AM
Here\'s some adapters I made just for this occasion.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#138891 08/01/2007 12:05 AM
Junior Member
Junior Member
I found a clutch housing today compleat with starter clutch and flywheel,my 292 had an automagic some were on here I seen some bolt on mounts for the side mounts does any one remember were to get these? will I have any interference problems with the rad to fan or rad to balancer?
thanks for any info
#138892 08/02/2007 12:25 PM
If your 292 had an automatic,don't forget to install a pilot bushing into the end of the crankshaft. Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
#138893 08/02/2007 9:29 PM
Riding in the Passing Lane
You will need to drill the mounting holes in the manual trans. flywheel out to 1/2 in. & get new bolts. The 292 used larger bolts then the others.
1972 Chevy c10 Cheyenne Super
#138894 08/03/2007 12:06 AM
use grade 8 bolts at the bell housing
yes i am doing this, a 292 into my 3104, w/ a T5, disc & dual master, corvette clutch and PP, 1977 1/2T suburban rear end.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00367.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00313.jpg
more shots every week
Jim & Caroline
