0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | has any one here done this swap? my clutch housing has the angled mounts,is there a clutch housing that will fit that cross member and bolt to the 292 engine? thanks for any info | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | V-8 bell housing from a '55 to '67 (I think) Chevy pickup. I'm not sure what clutch issues you might encounter, except to not some of those years Chevy used a hydraulic clutch.
The bell housing used on sixes starting in '63 and through the same year ('67?) will also work with the same clutch caveat.
The crossmember has those angled mounts starting in '54 and does make this swap easier.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here\'s some adapters I made just for this occasion. Scott | | | | | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | I found a clutch housing today compleat with starter clutch and flywheel,my 292 had an automagic some were on here I seen some bolt on mounts for the side mounts does any one remember were to get these? will I have any interference problems with the rad to fan or rad to balancer? thanks for any info | | | | | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | If your 292 had an automatic,don't forget to install a pilot bushing into the end of the crankshaft. Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need to drill the mounting holes in the manual trans. flywheel out to 1/2 in. & get new bolts. The 292 used larger bolts then the others. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
