3 members (5 Window 9434, MRMEROTH11, 1 invisible), 75 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#1388720 12/17/2020 6:42 AM
I'm about to install the headers and intake on my 261. Finally. I'm using felpro gaskets. Should I use gasket sealer?
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Clean and dry before install is all you need.
I use a little high heat sealer on exhaust ports and very small amount on the intake ports. The smoother the surfaces are, the less you need.
I am a believer in a skim coat on both sides of gasket when installing headers of a high heat silicone sealer. Exhaust gaskets will exploit the smallest leaking area and make it bigger over time. Seal the gasket fibers and it will prevent the later leaks.
