1 members (Peggy M), 74 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
Hey all,
Looking to identify an engine block casting of 3835335. Some sources state that this is a 1942-49 235 number, while at least one source states that it is a 216. Leaning towards the 235 as at least one reference is from a paper copy of a Chevrolet manual.
Any help clearing up this confusion?
Paul
Lots more pictures
My list shows it as a 216.
What Chevy manual shows it as a 235?
Jim Carter lists it as a 235.
I found another list showing it as a 235.
My list is probably incorrect.
2 Offline
Keep in mind a casting number is not a part number
A casting is pre-machined shape of metal
A part has been prepared post casting and is ready to install on the vehicle
In a few rare parts the two can be the same
But that would even preclude painting
Often for simple things the part number will be one off from the casting number
Sometimes when looking in parts books the casting number will be listed in the part description to help identify a part
I have seen instances where a casting is machined differently and can be found in 4 different part numbers
Engine heads were definitely machines different ways for different engines
But blocks I haven’t come across one but it could be possible
Maybe that is why the casting number can show up as multiple engines?
Copy and past from internet
FWIW
3835253 Chevrolet 48 — 49 216 FA, GA
3835309 Chevrolet 48 - 49 235 FDA,FDM,FEA,FEM
GDA,GDM,GEA,GEM
3835335 Chevrolet 47 235 EDA,EDM,EEA,EEM
Here's a copy of Group 0.033 Cylinder Block from my 1951 Parts Book.
It lists 3835335 as a 235 used from 1942-47
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
2 Offline
but also listed in this document as a 49-62 235 image attached
could be a typo that was transcribed when the author made this list
edit
source:
Cylinder Head and Block Manual April 2006
Compiled & edited
By
Mike Caruso, Steve Fox, Dave Hagen, Yolanda Carranza & Scott Groves
Copyright © AERA 2006 Printed in U.S.A.
AERA - Engine Builders Association 330 Lexington Drive
Buffalo Grove, IL 60089-6998
Tech Support - (888) 324-2372 (847) 541-6550
FAX (857) 541-5808
http://www.aera.org
-s
A 1941-49 216 or 235 will be designed for a full side cover.
A 1950 and later 235 will have a short side cover.
My Blog
Thanks guys,
I do believe this engine in question is in fact a 235.
Lots more pictures
My '46 truck 235 (splasher) also had '235' stamped on the side of the pan, look for that. I still have one of those pans if anyone is interested.
1946 1/2-Ton Chevy
