4 members (Chip O, Hotrod Lincoln, TooMany2count, 1 invisible), 88 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#138745 07/15/2007 4:34 PM
I put in a new gm LM1 290hp crate engine with edlebrock preformer intake and 600cfm carb that is calibrated for economy. I'm runing it through a 350 turbo tranny and a 3:08 rear. Dual exhaust with 40 series flowmasters. Its in my 61 panel daily driver. What should I expect for reasonable mpg? Right now I'm in the single digits and its costing me a fortune to run. I was hoping to get 12-13 mpg is that out of the question? Thanks
Mac
#138746 07/15/2007 6:22 PM
I would think you would get better than that, I have had many 350/auto trucks get 16 mpg regularly. Any brakes dragging? Timing? What do your plugs look like?
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#138747 07/15/2007 6:42 PM
Bricks don't get good milage, especially around town. Also, you probably occasionally accellerate hard and use the extra power you have. Most people I've talked to get about 9 MPG with Burbs. I had a 1968 F250 that got that milage in town with a 360 CID engine and the same milage after I installed a 300 horse 500 footpound 460 CID engine. The most I ever got with either engine was 14 MPG. The aerodynamics of your panel should be similar.
#138748 07/15/2007 8:12 PM
Riding in the Passing Lane
I think it should get better MPG,s than that. The performer carb is a little rich out of the box. You can get a calibration kit for it & try leaner jets &/or metering rods. Check your initial timing & advance mechanisms.
How does the 290 HP. idle with an automatic? I,ve always used the 260 HP model.
1972 Chevy c10 Cheyenne Super
#138749 07/15/2007 9:01 PM
Thanks for the input. New brakes all around (front disc conversion) so they are not dragging. Timing is on. I think its running rich but the plugs dont back that up. I purposely drove carefully after the last fill up and got 9 mpg. I am going to try and lean it out, hover edlebrock told me that this carb out of the box is fine? As for idleing with the 350 it idles great. As a side note my buddy with the same basic set up in his 63 pickup is getting 16 on the highway.
#138750 07/15/2007 11:39 PM
throw a K&N filter on it, that will help also. Synthetic oil helps too.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#138751 07/15/2007 11:44 PM
Already runnning mobil 1 and a k&N
Any other ideas?
Mac
#138752 07/16/2007 12:49 AM
remove 2 plug leads and use your mexican overdrive lol
#138753 07/16/2007 3:30 AM
I pulled down a consistant 16 MPG in my 350/SM465 combo with a 4 bbl Quad 64 C10. I see no reason why a 'burb shouldn't get simular mileage,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#138754 07/16/2007 2:01 PM
Edelbrock will tell you the same carb is jetted for economy or drag racing, whichever you are doing.
