1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13860 12/18/2003 2:25 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I put an ECI power brake booster on my new dual circuit master cylinder (same size as on old corvette) and it works great...but...when I push the pedal down very much, it seems to use so much vaccum that the engine tries to stall. I have the vaccum line going straight from the booster to my 292's manifold fitting just below the carb.
Any suggestions, O River of Knowledge?
I called ECI and they said I was using the wrong line (a 3/8 heater hose). NAPA sold me a fuel line and this one is 5/16 so it fits real tight on the barbs. I know its getting vaccum because the brakes are easy to apply.
Seems like mebe I could put an extra vaccum can on or something like you would use on a turbo motor??? :confused: | | |
#13861 12/18/2003 3:00 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I would try richening the air/fuel mixture. The power brake booster dumps air into the intake manifold you may be too lean to handle it.
if it dosen't need fixed, break it
#13862 12/18/2003 4:57 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Are you using vaccum hose? Not all hose is rated for vaccum systems. Just a thought: work in some steel tubing where possible to keep hose from being sucked flat. Also, you should check out the check valve on the line to the booster. These sometimes will fail, even got my 421 Pontiac v-8 to stumble! | | |
#13863 12/18/2003 5:26 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | You may want to check the booster to make sure there isn't a hole in the diaphram in the booster causing the vacuum to continue and not let it build up when ever you step on the brakes. What you describe is the symptoms of a hole in the booster diaphram.
kdot em3
#13864 12/18/2003 9:03 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | hmmmm....its a brand new booster! Never been used before. Mebe a check valve would work.... | | |
#13865 12/18/2003 10:03 AM | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | Install a check valve and see what happens. The 292 should be able to handle the booster with no problem, most all newer trucks used power brakes. The line won't have any effect on the engine side, booster won't work if its to small or sucked shut, the engine won't know the difference. Joe | | |
#13866 12/18/2003 10:38 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | talked to the guys at ECI, and they had a good suggestion. Remove the booster from the circuit, hit the brakes, and see what happens.
And...
its not the booster. with the booster off the vaccum line the same problem is there. Stalls. I hooked a vaccum gauge up and watched it, but I don't think its a vaccum issue.
So my timing light needs replacement, but I am going to go get another one, and then put it on and drive the truck and watch the flash as I go down the alley to see if it cuts out under braking.
Dunno what could be causing it at this point.
Engine has rebuilt carb and new fuel pump. Also has new spark plugs, wires, cap, and rotor. Wiring harness is brand new Painless Wiring 18 circuit universal (which I recommend). So in other words....tain't obvious at this point.
:confused: | | |
#13867 12/19/2003 12:21 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | timing light didn't reveal anything. I tried disconnect brake lights just in case that circuit was causing a problem. No difference. I tried just moving it about in driveway making the truck rock. Both back and forward make it cough. And that's with and without the brake booster on manifold vaccum. Without I put a piece of line on with a round punch jammed into it so the engine doesn't lean out. I am kinda stumped, but will keep monkeying with it. Any ideas, no matter how odd (relating to this problem  ) would be appreciated. | | |
#13868 12/19/2003 1:15 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | last test (least its nice outside here in texas - in 60s) I went in with a long socket extension and poked wires - all of them. No changes. I also made sure the battery cables were tight. No changes. Is it possible that fuel is sloshing about in the carb bowl causing the problem? I just had the carb rebuilt. This is a 1969 292 with a rochester one barrel #70045xx (xx = unreadable) and looks like: blury carb photo | | |
#13869 12/19/2003 1:28 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Remote (really!) possibility: Engine ground strap loose? You may be losing groound under deceleration. Carb is also a possibility. Maybe the float is set wrong and the port is uncovered while braking. This would occur almost immediately (I think). If the float is allowing too much fuel in during braking, there would probably be a slight lag between brake application and stalling.
Good luck! and Merry Christmas (or Happy Holidays, as the case may be)
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#13870 12/19/2003 8:47 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | too much fuel? I was thinking perhaps too little, as it would let the jet go dry. But, I can't see in there. I might call the carb shop and ask them what it should be set at, or open the top of the carb and see what the fuel level is. I suppose I could go both ways with it and see if I can get the thing to run right.
I have triple checked all the wiring, including the ground strap, and they are all tight and right. | | |
#13871 12/19/2003 1:43 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | hmmm,,,,, Have you looked at the wiring on the ignition switch under the dash? Any loose "HOT" wires hanging around under there? - OH,,, disconnect the vacuum advance and plug the vacuum line and see what happens.
#13872 12/19/2003 4:23 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | >> Is it possible that fuel is sloshing about in the carb bowl causing the problem? I just had the carb rebuilt.
This sounds logical to me - the float level in the carb may be set incorrectly.
When you do this, of course the gas in the carb bowl is sloshing.
To check the float level, you can just pull the top half off the carb without pulling the whole carb. I'd suggest buying a carb rebuild kit (about $14) - the kit has instructions for checking and setting the float level, and even includes a small ruler to measure the level.
Good Luck! | | |
#13873 12/19/2003 7:41 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | thanks boiz, no loose wires anywhere. I went and tugged on all of them.
Carb was rebuilt for me (off the truck) by a local shop that only does carbs. Going to run the truck over there as they want to see what's going on.
I just don't have a listing to know what the level should be. | | |
#13874 12/19/2003 10:05 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | and the answer is.... CARB FLOATS SET TOO HIGH! Tadah! Stump the chump.  (Just like with the tappet brothers) Took the old dog to the carb shop and after a couple of dissassemblies of the carb, the floats got set right. Fuel was sloshing about too much in there and mucking up the engine. So file that one away for future reference. Truck runs like a champ now. I am very pleased.  | | |
#13875 12/19/2003 11:29 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Ahh haaa! It was sounding like that might be da culprit.
Glad to hear you got it solved!
John | | |
#13876 12/19/2003 11:54 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | yup, give a chimp a banana and he eats for a day...
give a chimp a 59 1 ton, and he can get his own durn bananas.... | | |
#13877 12/20/2003 1:17 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Good to hear the truck is fixed and running healthy again
