| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Just wondering what a reasonable towing figure would be for my 56 1/2Ton PU. With SBC, TH350, Tranny cooler, 3.79 rearend, Camaro Subframe, if I were to install a Class II or III hitch, could I tow my car trailer and 3500lb load (Farmtrac 270 DTC Tractor) behind me safely? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | stopping is more important than how much you can haul. with my 79 ford courier i hauled 3500 pounds plus the trailer weight but it took two blocks to stop. bottom line what are you using for brakes? ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I would say it could be done reasonably safe with brakes on the trailer that are hooked up and working. I would not want to go very far though. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If in doubt get a bigger truck.
With the Camaro clip you have pasenger car class brakes designed to stop a car that might have weighed 4000 pounds fully loaded. Your truck isn't likely to weigh any more than that, but doesn't weigh much less either.
Add that 3500 pound load and 1500 pounds of trailer, plus anything you put in the bed of the truck, and your cargo weighs nearly twice the truck and twice what your brakes are designed to stop.
So if you have good trailer brakes and keep them in perfect repair you are probably safe. As long as nothing goes wrong. My own solution is to use a 1-ton pickup to pull my car trailer. Something could still fail, but the margin before I'm in trouble is much greater.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
