Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1385756 11/24/2020 7:20 PM
Any ideas what this thing might be? I'm guessing a jack of some sort?
Another quality post.
Real Trucks Rattle
Rusty Rod #1385759 11/24/2020 8:32 PM
That would be my guess too. What happens when you pump the handle? I'm guessing that the center post just raises a bit. The upper part gets positioned as far up as possible, then pushing the handle levers the center post up just a bit. Maybe some sort of aligning jack, as it doesn't look like it can move very far.
I've never seen anything like it.
Rusty Rod #1385765 11/24/2020 9:05 PM
Moderator
Moderator
2 Offline
Looks homemade to me and built for a special purpose.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Rusty Rod #1385771 11/24/2020 9:35 PM
I doubt it's homemade. The DIY guy would probably use bolts instead of rivets to hold it together.
Rusty Rod #1385808 11/25/2020 2:38 AM
At the moment it is stuck, so I don't know what it does. It might even be missing some springs?
Real Trucks Rattle
Rusty Rod #1385836 11/25/2020 12:58 PM
Interesting how the base has holes in it indicating that it may have been fixed to a single location. Perhaps a type of press?
Lots more pictures
Rusty Rod #1385889 11/25/2020 6:05 PM
A load leveler of some type?
Rusty Rod #1385895 11/25/2020 7:21 PM
Have you looked for any kind of markings on it? Sure would be interesting to find a manufacturer's name or part number to research it some more.
Rusty Rod #1385962 11/26/2020 2:37 AM
There are no markings on it that are obvious.
I did spray it with some break free and got it "working". The handle raises the frame up a few inches. The widget that is sticking out on the top is adjustable to the notches.
Real Trucks Rattle
Rusty Rod #1385964 11/26/2020 2:38 AM
2 Offline
if someone wants one of those strange flat no marking jacks there is one for sale in northern cali
$10
not mine but i can PM you the craiglist post, unless it's okay to post it here
-s
Rusty Rod #1385966 11/26/2020 2:44 AM
Post the link here, I'd like to see what it is used for.. curiosity you know.
Real Trucks Rattle
Rusty Rod #1385969 11/26/2020 2:51 AM
2 Offline
not a lot of info in that link
-s
Rusty Rod #1385979 11/26/2020 4:32 AM
The only way that would be useful would be to adjust the upper hook under something, push the handle down, to raise the item, stick a block under it, raise the handle, readjust the hook, push the handle down, insert a block, etc, etc, etc. ohwell Wouldn't work for a vehicle, because the suspension probably would relax before the tire got off the ground to block it up. I guess you could block it under the frame or bumper.
Rusty Rod #1386023 11/26/2020 4:05 PM
I got an answer from the craigslist ad. He has no clue either, but it did belong to his grandfather.
Real Trucks Rattle
Rusty Rod #1386024 11/26/2020 4:08 PM
I'll move this to the tool shed and see if anyone over there knows. thanks for the input, so far.
Real Trucks Rattle
Rusty Rod #1386059 11/26/2020 7:52 PM
My vote is it's a Buckboard/Wagon Jack.
How tall is it?
Looks like the lifting paw ratchets up and down the cogged teeth on the shaft, right?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Rusty Rod #1386136 11/27/2020 4:51 AM
It's about 26-27" tall. The pawl? slides up and down, it sits on the teeth. The handle lifts it about 4 inches or so.
Real Trucks Rattle
Rusty Rod #1386159 11/27/2020 1:58 PM
Definitely a specialty jack for a specific application. Doesn’t appear very heavy duty.
Justhorsenround #1386173 11/27/2020 4:38 PM
Professional procrastinator
Any chance you could pm the link to me? I am in northern CA and that would look cool in my garage thumbs_up
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Rusty Rod #1386182 11/27/2020 6:02 PM
2 Offline
figured it out
it's just one of many early carriage jacks, used for holding them up for wheel service, that's why it starts so high off the ground and it not very strong, do not lift heavy loads and never trust it with more than your friends foot.
once you know what to look for they are not difficult to find
hi Twin Jimmys,
the link i posted earlier is gone now, i can't find the post on craigslist either, but i found another one in 1 minute knowing what to look for, i'll PM you that one, it's a bit more pricey but it's in better shape.
-stan
Rusty Rod #1386251 11/28/2020 1:34 AM
Depending on the type of carriage ( lightweight ), probably a single horse. There were jack ports on the sides. Somewhat like VW and Porsche used for there heavy side lifting. This jack would only lift about as much as one man but, would free up a person to adjust axle bolt. Most were Blacksmith made. Doc.
Moderated by  MNSmith
